[Swift-devel] Cache error in Swift
    Jonathan Monette
    jonmon at mcs.anl.gov
    Wed Sep 14 23:03:11 CDT 2011
I am pretty sure I am not.  All the input files are unique and the output files are all mapped using the regexp mapper and appending proj_ to the front.
But I will check anyways.  I seem to be having the error without replications as well.  Let me try a couple more runs to see if I added something erroneously.
On Sep 14, 2011, at 10:43 PM, Mihael Hategan wrote:
> I suppose it might be possible to have a race condition when using
> replication such that two jobs in the same replication group complete.
> But before I go and dig into that, can you double-check that you are not
> mapping two things to the same file?
> On Wed, 2011-09-14 at 17:33 -0500, Jonathan Monette wrote:
>> Hello,
>>   I just ran my SwiftMontage scripts again with the most recent build of 0.93 source.  I received this error
>> Execution failed:
>> 	The cache already contains pads:montage-20110914-1717-nrothtg3/shared/proj_dir/proj_2mass-atlas-000713s-j0870197.fits.
>> I received this error after 3652 tasks.  All the files are located in /home/jonmon/PADS/Swift/SwiftMontage/big/run.0013 on the CI machines.
>> I wanted to try replications.  I have noticed in my scripts that when PADS is full of jobs Swift doesn't try to resubmit to Beagle even though Beagle shows through showq  that it has room for jobs.  I thought replications would use both sites more efficiently.  What I mean is I thought that replications would replicate a jobs onto Beagle since PADS is taking so long just sitting in the queue.
>> Please educate me if this is not what I should be doing and if in fact there is no work around to this problem.
