[Swift-devel] Path.parse(path.toString())
Ketan Maheshwari
ketancmaheshwari at gmail.com
Mon Sep 12 17:01:03 CDT 2011
Hello,
Today I saw this error on SCEC workflow.
could not find variable:
_concurrent/var_str-d9e801ee-8aca-431f-99a0-8286c452c779-13-6 [7]
Invalid path exception org.griphyn.vdl.mapping.InvalidPathException: Invalid
path ([7]) for var_str:string[0] - Closed for path [7]
org.griphyn.vdl.mapping.InvalidPathException: Invalid path ([7]) for
at
org.griphyn.vdl.mapping.AbstractDataNode.getField(AbstractDataNode.java:204)
at org.griphyn.vdl.mapping.file.ArrayFileMapper.map(ArrayFileMapper.java:55)
at
org.griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:281)
at
org.griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:270)
at org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:187)
at org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:175)
at org.griphyn.vdl.karajan.lib.Stagein.function(Stagein.java:54)
at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:62)
at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.futureModified(AbstractSequentialWithArguments.java:208)
at
org.griphyn.vdl.karajan.DSHandleFutureWrapper$1.run(DSHandleFutureWrapper.java:63)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Execution failed:
Progress: time: Mon, 12 Sep 2011 16:50:27 -0500 Submitted:1 Active:17
Finished successfully:10
Complete log for this run is:
http://www.ci.uchicago.edu/~ketan/postproc-20110912-1642-epj1ebm1.log
Swift is r5102.
Ketan
On Fri, Sep 9, 2011 at 9:33 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> So far Im not able to re-create this problem on the prior revision of 0.93.
> Im currently using this variation of the script Mihael posted below:
> type file;
> type struct {
> file b;
> file c;
> app (struct of) echo() {
> sh "-c" "echo bee >fileb ; echo see >filec";
> struct s <ext;exec="structbug1.map">;
> s = echo();
> I discovered what I think is a new bug in the process: if the shell command
> string contains the characters >&1 and >&2, Swift complains that it cant
> process the intermediate xml. Presumably those shell sequences are getting
> xml parsing confused and need to be escaped.
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "David Kelly" <davidk at ci.uchicago.edu>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Friday, September 9, 2011 1:31:44 AM
> > Subject: Re: [Swift-devel] Path.parse(path.toString())
> > On Fri, 2011-09-09 at 01:10 -0500, David Kelly wrote:
> > > It looks like there are a few scripts in the test suite which write
> > > structs and seem to be passing.
> > I suspect they are not staging structs out (just in).
> > > Do you happen to have an example script I could add to the suite?
> > type file;
> > type struct {
> > file b;
> > file c;
> > bash "echo bee >1 ; echo see >2" stdout=@filename(of.b)
> > stderr=@filename(of.c);
> > struct s <simple_mapper;>;
> > s = echo();
> > (I'm not sure if this actually works if the bug is fixed, but I know
> > it
> > doesn't if it isn't. Anyway, you get the idea).
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110912/8c6935f9/attachment.html>
