[Swift-devel] coasters won't start
Ketan Maheshwari
ketancmaheshwari at gmail.com
Fri Oct 21 13:58:57 CDT 2011
Jon,
There were some changes in the firewalls rules in terms of allowed open
ports on various ci machines. A long shot, but may be you want to check on
that.
Can you paste your sites.xml and I can take a look if I find something.
Ketan
On Fri, Oct 21, 2011 at 1:50 PM, Jonathan Monette <jonmon at mcs.anl.gov>wrote:
> Anyone have a thought on this? Not sure what is wrong. I can't seem to
> get coasters registered from PADS or Beagle. The log also specifies a
> FileNotFoundException when trying to transfer back the wrapper log. Does
> this have something to do with the problem? I have been assuming that this
> error was being thrown due to the coaster service not connecting.
> On Oct 20, 2011, at 3:04 PM, Jonathan Monette wrote:
> Here is a log saying that the coaster service isn't starting, at least that
> is what the log is saying. This is with on PADS with automatic coasters
> using 0.93RC3.
> http://www.ci.uchicago.edu/~jonmon/logs/coasters_wont_start.log
> And here is the coaster log in zipped form
> http://www.ci.uchicago.edu/~jonmon/logs/coasters.tar.gz
> All the files used for this run are located in
> ~jonmon/PADS/Swift/SwiftMontage/m101_tutorial/run.0039 on the ci network.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111021/0036dc02/attachment.html>
