[Swift-devel] OpenMP example for Swift testing
Michael Wilde
wilde at mcs.anl.gov
Mon Oct 17 18:00:54 CDT 2011
Im a total newbie to OpenMP (so this may be a flawed example), but this seems to work:
#include <stdio.h>
void main(int argc, char **argv)
int i;
#pragma omp parallel for private (i)
for(i=0; i<10; i++){
printf("i=%d sleeps\n",i);
system("sleep 2");
printf("i=%d wakes\n", i);
make with:
openmpapp: openmpapp.c
gcc -fopenmp -o openmpapp openmpapp.c
And try the same code with the #pragma commented out.
Under OpenMP you can see how the threads behave:
sandbox$ OMP_NUM_THREADS=2 ./openmpapp
i=0 sleeps
i=5 sleeps
i=5 wakes
i=6 sleeps
i=0 wakes
i=1 sleeps
i=6 wakes
i=7 sleeps
i=1 wakes
i=2 sleeps
i=7 wakes
i=8 sleeps
i=2 wakes
i=3 sleeps
i=8 wakes
i=9 sleeps
i=3 wakes
i=4 sleeps
i=9 wakes
i=4 wakes
sandbox$ OMP_NUM_THREADS=10 ./openmpapp
i=2 sleeps
i=9 sleeps
i=0 sleeps
i=7 sleeps
i=8 sleeps
i=5 sleeps
i=6 sleeps
i=4 sleeps
i=3 sleeps
i=1 sleeps
i=9 wakes
i=5 wakes
i=8 wakes
i=4 wakes
i=6 wakes
i=3 wakes
i=1 wakes
i=0 wakes
i=2 wakes
i=7 wakes
sandbox$
One thing that has me stumped, though, is that asking for 9 threads shows a behavior as if it had 5 threads:
sandbox$ OMP_NUM_THREADS=9 ./openmpapp
i=4 sleeps
i=0 sleeps
i=8 sleeps
i=6 sleeps
i=2 sleeps
i=8 wakes
i=9 sleeps
i=4 wakes
i=5 sleeps
i=0 wakes
i=1 sleeps
i=6 wakes
i=7 sleeps
i=2 wakes
i=3 sleeps
i=1 wakes
i=7 wakes
i=9 wakes
i=3 wakes
i=5 wakes
sandbox$
I also would not assume that printf() and system() are thread-safe, but at least this is a simple example to start out with for testing if we're getting the right number of cores and threads active under Swift, Coasters, and Cray ALPS/aprun.
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Glen Hocky" <hockyg at uchicago.edu>
> Cc: "David Kelly" <davidk at ci.uchicago.edu>, "ketan" <ketancmaheshwari at gmail.com>, "Swift Devel"
> <swift-devel at ci.uchicago.edu>, "Justin M Wozniak" <wozniak at mcs.anl.gov>
> Sent: Monday, October 17, 2011 11:52:54 AM
> Subject: Re: [Swift-devel] Where is latest doc on running Swift on Beagle? Covers OpenMP apps?
> I can help write a test case. Its just a for() loop with a #pragma in
> front - very simple. If each parallel loop iteration could do
> system("sleep N") we could readily observe that the test is working
> and spawning OMP_NUM_THREADS threads and procs.
> - Mike
> > From: "Glen Hocky" <hockyg at uchicago.edu>
> > To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> > Cc: "Michael Wilde" <wilde at mcs.anl.gov>, "David Kelly"
> > "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Monday, October 17, 2011 11:30:17 AM
> > Justin, I'm not sure my program counts as sufficiently simple for
> > this
> > purpose. I'd be happy to let you include it and get an example set
> > up
> > though if you want to use it anyway. The open mp part, which I
> > haven't
> > been using recently, may need a bit of debugging as well
> > Glen
> > On Mon, Oct 17, 2011 at 12:23 PM, Justin M Wozniak <
> > wozniak at mcs.anl.gov > wrote:
> > Glen, do you have an extremely simple but relevant OpenMP program
> > that
> > we could stick in the test suite?
> > On Sun, 16 Oct 2011, Glen Hocky wrote:
> > It's in my run script that creates the actual sites file that I run
> > with.
> > I'm not sure what you would do if you wanted more than 24 cores, so
> > depth
> > stays fixed at 24 (that's an aprun parameters). Then
> > WORKERSPERNODE=$((24/$PPN))
> > Where PPN is how many cores you want per OPENMP app and then workers
> > per
> > node says how many OPENMP apps you want to run. So obvious example
> > would be
> > you want 3 8 core OPENMP jobs, PPN = 8, WORKERSPERNODE=3
> > On Sun, Oct 16, 2011 at 12:27 PM, Michael Wilde < wilde at mcs.anl.gov
> > wrote:
> > Thanks, Glen!
> > Justin, can you check the sites file below? I dont understand the
> > interaction between the parameters OMP_NUM_THREDS, jobsPerNode, and
> > depth.
> > WHere is the best documentation on that?
> > Thanks,
> > - Mike
> > From: "Glen Hocky" < hockyg at uchicago.edu >
> > To: "Michael Wilde" < wilde at mcs.anl.gov >
> > Cc: "David Kelly" < davidk at ci.uchicago.edu >, "ketan" <
> > ketancmaheshwari at gmail.com >
> > Sent: Sunday, October 16, 2011 11:18:33 AM
> > Yes, I'm running and yes I did test openmp a while back. Sites file
> > follows. I'm using trunk from a few months ago
> > "Swift svn swift-r4813 (swift modified locally) cog-r3175"
> > <pool handle="pbs-beagle-coasters">
> > <execution provider="coaster" jobmanager="local:pbs" url="none"/>
> > <filesystem provider="local"/>
> > <profile namespace="globus"
> > key="providerAttributes">pbs. aprun;pbs.mpp;depth=24</ profile>
> > <profile key="jobsPerNode" namespace="globus">24</ profile>
> > <profile namespace="env" key="OMP_NUM_THREADS">$PPN</ profile>
> > <profile namespace="globus" key="maxwalltime">$TIME</ profile>
> > <profile namespace="globus" key="maxTime">$MAXTIME</ profile>
> > <profile namespace="globus" key="slots">$nodes</profile>
> > <profile namespace="globus" key="nodeGranularity">1</ profile>
> > <profile namespace="globus" key="maxNodes">1</profile>
> > <profile namespace="globus" key="lowOverAllocation">100</ profile>
> > <profile namespace="globus" key="highOverAllocation">100</ profile>
> > <profile namespace="karajan" key="jobThrottle">200.00</ profile>
> > <profile namespace="karajan" key="initialScore">10000</ profile>
> > <workdirectory >$swiftrundir/swiftwork</ workdirectory>
> > </pool>
> > On Sun, Oct 16, 2011 at 12:15 PM, Michael Wilde < wilde at mcs.anl.gov
> > wrote:
> > David, Ketan,
> > I need to run some things on Beagle, asap.
> > Ketan, where is the latest and best documentation for this? I see
> > your
> > edits below to the 0.93 Site Guide. But I dont see that online where
> > I
> > would expect it:
> > http://www.ci.uchicago.edu/ swift/wwwdev/guides/release-0.
> > 93/siteguide/siteguide.html#_ beagle
> > David, is it just that this document is not being correctly pushed
> > to
> > the wwwdev site on a nightly basis?
> > Ketan, is the latest info on running Swift on Beagle now all in the
> > siteguide? Is the info you were putting in the cookbook (I see many
> > commits there) now all consolidated into the Site Guide? And is
> > there
> > a difference in sites.xml settings between 0.93 and trunk? Lastly,
> > which release works best?
> > Second question: I need to run a script that executes many 24-core
> > OpenMP apps. Is the necessary support for this in 0.93? What if any
> > declarations do I need other than to say jobsPerNode=1? Glen, are
> > you
> > running OpenMP on Beagle and if so what release and sites file are
> > you
> > using?
> > Im assuming Justin's latest changes to sites.xml are in trunk but
> > not
> > 0.93? If that is correct, is there a corresponding site site for
> > Beagle for trunk?
> > Thanks,
> > - Mike
> > ----- Forwarded Message -----
> > From: ketan at ci.uchicago.edu
> > To: swift-commit at ci.uchicago.edu
> > Sent: Sunday, September 18, 2011 10:14:10 PM
> > Subject: [Swift-commit] r5126 - branches/release-0.93/docs/
> > siteguide
> > Author: ketan
> > Date: 2011-09-18 22:14:10 -0500 (Sun, 18 Sep 2011)
> > New Revision: 5126
> > Modified:
> > branches/release-0.93/docs/ siteguide/beagle
> > Log:
> > added content to beagle siteguide
> > Modified: branches/release-0.93/docs/ siteguide/beagle
> > --- branches/release-0.93/docs/ siteguide/beagle 2011-09-19 02:41:02
> > UTC (rev 5125)
> > +++ branches/release-0.93/docs/ siteguide/beagle 2011-09-19 03:14:10
> > UTC (rev 5126)
> > @@ -52,9 +52,38 @@
> > A key factor in scaling up Swift runs on Beagle is to setup the
> > sites.xml parameters.
> > The following sites.xml parameters must be set to scale that is
> > intended for a large run:
> > - * walltime: The expected walltime for completion of your run. This
> > parameter is accepted in seconds.
> > - * slots: Number of qsub jobs needs to be submitted by swift. This
> > number will determine how many qsubs swift will submit for your run.
> > Typical values range between 40 and 80 for large runs.
> > - * nodegranularity: Determines the number of nodes per job. Total
> > nodes will thus be slots times nodegranularity. This may vary for
> > advanced configurations though.
> > - * maxnodes: Determines the maximum number of nodes a job must pack
> > into its qsub. This parameter determines the largest single job that
> > your run will submit.
> > + * *maxTime* : The expected walltime for completion of your run.
> > This
> > + * *slots* : Number of qsub jobs needs to be submitted by swift.
> > This
> > + * *nodeGranularity* : Determines the number of nodes per job.
> > Total
> > + * *maxNodes* : Determines the maximum number of nodes a job must
> > pack into its qsub. This parameter determines the largest single job
> > that your run will submit.
> > + * *jobThrottle* : A factor that determines the number of tasks
> > dispatched simultaneously. The intended number of simultaneous tasks
> > must match the number of cores targeted. The number of tasks is
> > calculated from the jobThrottle factor is as follows:
> > +Number of Tasks = (JobThrottle x 100) + 1
> > +Following is an example sites.xml for a 50 slots run with each slot
> > occupying 4 nodes (thus, a 200 node run):
> > +<config>
> > + <pool handle="pbs">
> > + <execution provider="coaster" jobmanager="local:pbs"/>
> > + <profile namespace="globus" key="project">CI-CCR000013</ profile>
> > + <profile namespace="globus" key="ppn">24:cray:pack</ profile>
> > + <profile namespace="globus" key="jobsPerNode">24</profile>
> > + <profile namespace="globus" key="maxTime">50000</profile>
> > + <profile namespace="globus" key="slots">50</profile>
> > + <profile namespace="globus" key="nodeGranularity">4</ profile>
> > + <profile namespace="globus" key="maxNodes">4</profile>
> > + <profile namespace="karajan" key="jobThrottle">48.00</ profile>
> > + <profile namespace="karajan" key="initialScore">10000</ profile>
> > + <filesystem provider="local"/>
> > + <workdirectory >/lustre/beagle/ketan/swift.
> > workdir</workdirectory>
> > + </pool>
> > +</config>
> > ______________________________ _________________
> > Swift-commit mailing list
> > Swift-commit at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/ cgi-bin/mailman/listinfo/
> > swift-commit
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/ cgi-bin/mailman/listinfo/ swift-devel
> > Michael Wilde
> > Justin M Wozniak
> Michael Wilde
Michael Wilde
