[Swift-devel] Where is latest doc on running Swift on Beagle? Covers OpenMP apps?
Justin M Wozniak wozniak at mcs.anl.gov
Mon Oct 17 11:23:02 CDT 2011
Glen, do you have an extremely simple but relevant OpenMP program that we
could stick in the test suite?
On Sun, 16 Oct 2011, Glen Hocky wrote:
> It's in my run script that creates the actual sites file that I run with.
> I'm not sure what you would do if you wanted more than 24 cores, so depth
> stays fixed at 24 (that's an aprun parameters). Then
>    WORKERSPERNODE=$((24/$PPN))
> Where PPN is how many cores you want per OPENMP app and then workers per
> node says how many OPENMP apps you want to run. So obvious example would be
> you want 3 8 core OPENMP jobs, PPN = 8, WORKERSPERNODE=3
> On Sun, Oct 16, 2011 at 12:27 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Thanks, Glen!
>> Justin, can you check the sites file below?  I dont understand the
>> interaction between the parameters OMP_NUM_THREDS, jobsPerNode, and depth.
>>  WHere is the best documentation on that?
>> Thanks,
>> - Mike
>> ----- Original Message -----
>>> From: "Glen Hocky" <hockyg at uchicago.edu>
>>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>>> Cc: "David Kelly" <davidk at ci.uchicago.edu>, "ketan" <
>> ketancmaheshwari at gmail.com>
>>> Sent: Sunday, October 16, 2011 11:18:33 AM
>>> Subject: Re: [Swift-devel] Where is latest doc on running Swift on
>>> Yes, I'm running and yes I did test openmp a while back. Sites file
>>> follows. I'm using trunk from a few months ago
>>> "Swift svn swift-r4813 (swift modified locally) cog-r3175"
>>> <pool handle="pbs-beagle-coasters">
>>> <execution provider="coaster" jobmanager="local:pbs" url="none"/>
>>> <filesystem provider="local"/>
>>> <profile namespace="globus"
>>> key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
>>> <profile key="jobsPerNode" namespace="globus">24</profile>
>>> <profile namespace="env" key="OMP_NUM_THREADS">$PPN</profile>
>>> <profile namespace="globus" key="maxwalltime">$TIME</profile>
>>> <profile namespace="globus" key="maxTime">$MAXTIME</profile>
>>> <profile namespace="globus" key="slots">$nodes</profile>
>>> <profile namespace="globus" key="nodeGranularity">1</profile>
>>> <profile namespace="globus" key="maxNodes">1</profile>
>>> <profile namespace="globus" key="lowOverAllocation">100</profile>
>>> <profile namespace="globus" key="highOverAllocation">100</profile>
>>> <profile namespace="karajan" key="jobThrottle">200.00</profile>
>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>> <workdirectory >$swiftrundir/swiftwork</workdirectory>
>>> </pool>
>>> On Sun, Oct 16, 2011 at 12:15 PM, Michael Wilde < wilde at mcs.anl.gov >
>>> wrote:
>>> David, Ketan,
>>> I need to run some things on Beagle, asap.
>>> Ketan, where is the latest and best documentation for this? I see your
>>> edits below to the 0.93 Site Guide. But I dont see that online where I
>>> would expect it:
>> http://www.ci.uchicago.edu/swift/wwwdev/guides/release-0.93/siteguide/siteguide.html#_beagle
>>> David, is it just that this document is not being correctly pushed to
>>> the wwwdev site on a nightly basis?
>>> Ketan, is the latest info on running Swift on Beagle now all in the
>>> siteguide? Is the info you were putting in the cookbook (I see many
>>> commits there) now all consolidated into the Site Guide? And is there
>>> a difference in sites.xml settings between 0.93 and trunk? Lastly,
>>> which release works best?
>>> Second question: I need to run a script that executes many 24-core
>>> OpenMP apps. Is the necessary support for this in 0.93? What if any
>>> declarations do I need other than to say jobsPerNode=1? Glen, are you
>>> running OpenMP on Beagle and if so what release and sites file are you
>>> using?
>>> Im assuming Justin's latest changes to sites.xml are in trunk but not
>>> 0.93? If that is correct, is there a corresponding site site for
>>> Beagle for trunk?
>>> Thanks,
>>> - Mike
>>> ----- Forwarded Message -----
>>> From: ketan at ci.uchicago.edu
>>> To: swift-commit at ci.uchicago.edu
>>> Sent: Sunday, September 18, 2011 10:14:10 PM
>>> Subject: [Swift-commit] r5126 - branches/release-0.93/docs/siteguide
>>> Author: ketan
>>> Date: 2011-09-18 22:14:10 -0500 (Sun, 18 Sep 2011)
>>> New Revision: 5126
>>> Modified:
>>> branches/release-0.93/docs/siteguide/beagle
>>> Log:
>>> added content to beagle siteguide
>>> Modified: branches/release-0.93/docs/siteguide/beagle
>>> --- branches/release-0.93/docs/siteguide/beagle 2011-09-19 02:41:02
>>> UTC (rev 5125)
>>> +++ branches/release-0.93/docs/siteguide/beagle 2011-09-19 03:14:10
>>> UTC (rev 5126)
>>> @@ -52,9 +52,38 @@
>>> A key factor in scaling up Swift runs on Beagle is to setup the
>>> sites.xml parameters.
>>> The following sites.xml parameters must be set to scale that is
>>> intended for a large run:
>>> - * walltime: The expected walltime for completion of your run. This
>>> parameter is accepted in seconds.
>>> - * slots: Number of qsub jobs needs to be submitted by swift. This
>>> number will determine how many qsubs swift will submit for your run.
>>> Typical values range between 40 and 80 for large runs.
>>> - * nodegranularity: Determines the number of nodes per job. Total
>>> nodes will thus be slots times nodegranularity. This may vary for
>>> advanced configurations though.
>>> - * maxnodes: Determines the maximum number of nodes a job must pack
>>> into its qsub. This parameter determines the largest single job that
>>> your run will submit.
>>> + * *maxTime* : The expected walltime for completion of your run. This
>>> + * *slots* : Number of qsub jobs needs to be submitted by swift. This
>>> + * *nodeGranularity* : Determines the number of nodes per job. Total
>>> + * *maxNodes* : Determines the maximum number of nodes a job must
>>> pack into its qsub. This parameter determines the largest single job
>>> that your run will submit.
>>> + * *jobThrottle* : A factor that determines the number of tasks
>>> dispatched simultaneously. The intended number of simultaneous tasks
>>> must match the number of cores targeted. The number of tasks is
>>> calculated from the jobThrottle factor is as follows:
>>> +Number of Tasks = (JobThrottle x 100) + 1
>>> +Following is an example sites.xml for a 50 slots run with each slot
>>> occupying 4 nodes (thus, a 200 node run):
>>> +<config>
>>> + <pool handle="pbs">
>>> + <execution provider="coaster" jobmanager="local:pbs"/>
>>> + <profile namespace="globus" key="project">CI-CCR000013</profile>
>>> + <profile namespace="globus" key="ppn">24:cray:pack</profile>
>>> + <profile namespace="globus" key="jobsPerNode">24</profile>
>>> + <profile namespace="globus" key="maxTime">50000</profile>
>>> + <profile namespace="globus" key="slots">50</profile>
>>> + <profile namespace="globus" key="nodeGranularity">4</profile>
>>> + <profile namespace="globus" key="maxNodes">4</profile>
>>> + <profile namespace="karajan" key="jobThrottle">48.00</profile>
>>> + <profile namespace="karajan" key="initialScore">10000</profile>
>>> + <filesystem provider="local"/>
>>> + <workdirectory >/lustre/beagle/ketan/swift.workdir</workdirectory>
>>> + </pool>
>>> +</config>
>>> _______________________________________________
>>> Swift-commit mailing list
>>> Swift-commit at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-commit
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Michael Wilde
Justin M Wozniak
