[Swift-devel] Swift command not recognizing options
Jonathan Monette
jonmon at mcs.anl.gov
Tue Oct 11 17:23:31 CDT 2011
Hello,
I do not believe Swift is honoring any options passed to it in trunk. Here is my command line:
swift -sites.file sites.xml -tc.file tc.data -config swift.properties montage.swift
But the execution goes like this:
[jonmon at communicado: ~/PADS/Swift/SwiftMontage/m101_tutorial/run.0030]$ swift -sites.file sites.xml -tc.file tc.data -config swift.properties montage.swift
Swift version: 0.93
/home/jonmon/Library/Swift/bin/../etc/sites.xml
Swift svn swift-r5219 cog-r3296
RunID: 20111011-1719-std6z8pa
(input): found 10 files
Progress: time: Tue, 11 Oct 2011 17:19:25 -0500
Progress: time: Tue, 11 Oct 2011 17:19:28 -0500 Selecting site:8 Stage in:1 Submitting:1
Progress: time: Tue, 11 Oct 2011 17:19:31 -0500 Selecting site:8 Active:1 Checking status:1
EXCEPTION Exception in mProjectPP_wrap:
Arguments: [-X, raw_dir/raw_image_3.fits, proj_dir/proj_raw_image_3.fits, header.hdr]
Host: localhost
Directory: montage-20111011-1719-std6z8pa/jobs/d/mProjectPP_wrap-dc0bd6hk
stderr.txt:
stdout.txt:
Caused by: Swift config property "wrapperlog.always.transfer" not found in Swift configuration [swift.properties]
Execution failed:
Arguments: [-X, raw_dir/raw_image_7.fits, proj_dir/proj_raw_image_7.fits, header.hdr]
Host: localhost
Directory: montage-20111011-1719-std6z8pa/jobs/c/mProjectPP_wrap-cc0bd6hk
stderr.txt:
stdout.txt:
I do not have wrapperlog.always.transfer in my properties file. I have wrapper.log.always.transfer:
[jonmon at communicado: ~/PADS/Swift/SwiftMontage/m101_tutorial/run.0030]$ cat swift.properties
execution.retries=0
sitedir.keep=true
status.mode=provider
wrapper.log.always.transfer=true
foreach.maxthreads=1024
wrapper.parameter.mode=files
use.provider.staging=false
provider.staging.pin.swiftfiles=false
Did something sneak into the trunk version that doesn't honor the command line options?
