[Swift-devel] [Swift-commit] r5316	-	in	branches/release-0.93/src/org/griphyn/vdl: karajan/lib mapping
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Nov 25 19:59:19 CST 2011
Actually, looking at the error message more closely I am not sure my comment below is correct. The message may be complaining about the array object as a whole, and the [2] may be stating the number of elements (the array does indeed have 2 elements) as opposed to a member of the array that it believes is not mapped.
I need to experiment further.  Do you see an error in the test case?
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: hategan at ci.uchicago.edu
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Friday, November 25, 2011 7:52:26 PM
> Subject: Re: [Swift-devel] [Swift-commit] r5316 - in branches/release-0.93/src/org/griphyn/vdl: karajan/lib mapping
> Mihael, this does not fix the bug that I reported in bug 644, but it
> does seem to clarify the cause: the test case in bug 644 now gives the
> message:
> ?:file[2] - Closed is not a mapped type
> @filenames() should only be looking at array elements [0] and [1] -
> seems to me that its going beyond the assigned elements of the array
> to complain about [2] not being mapped. If I set element [2] it
> complains about element [3] in the error message above.
> Did you try the test case? That case should not generate an error - I
> believe that its a valid program. if you replace @filenames() with two
> calls to @filename() it works. Ie all elements of the array passed to
> @filenames() are properly mapped.
> - Mike
> > From: hategan at ci.uchicago.edu
> > To: swift-commit at ci.uchicago.edu
> > Sent: Thursday, November 24, 2011 3:18:52 PM
> > Subject: [Swift-commit] r5316 - in
> > Author: hategan
> > Date: 2011-11-24 15:18:51 -0600 (Thu, 24 Nov 2011)
> > New Revision: 5316
> > Modified:
> > branches/release-0.93/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
> > branches/release-0.93/src/org/griphyn/vdl/mapping/AbstractDataNode.java
> > branches/release-0.93/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
> > branches/release-0.93/src/org/griphyn/vdl/mapping/RootDataNode.java
> > Log:
> > throw better exception than NPE when @filename is called with a
> > non-mapped argument
> > Modified:
> > 2011-11-23 19:33:26 UTC (rev 5315)
> > 2011-11-24 21:18:51 UTC (rev 5316)
> > @@ -197,8 +197,17 @@
> > private static String[] leavesFileNames(DSHandle var) throws
> > ExecutionException, HandleOpenException {
> > Mapper mapper;
> > synchronized (var.getRoot()) {
> > - mapper = var.getMapper();
> > + if (var instanceof AbstractDataNode) {
> > + mapper = ((AbstractDataNode) var).getActualMapper();
> > + if (mapper == null) {
> > + throw new ExecutionException(var + " is not a mapped type");
> > + else {
> > + mapper = var.getMapper();
> > List<String> l = new ArrayList<String>();
> > try {
> > Modified:
> > @@ -513,7 +513,7 @@
> > - protected Mapper getActualMapper() {
> > + public Mapper getActualMapper() {
> > return null;
> > Modified:
> > @@ -103,7 +103,7 @@
> > throw new
> > FutureNotYetAvailable(waitingMapperParam.getFutureWrapper());
> > return mapper;
> > Modified:
> > @@ -213,7 +213,7 @@
> > throw new
> > return mapper;
> > _______________________________________________
> > Swift-commit mailing list
> > Swift-commit at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-commit
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
