[Swift-devel] arrays of files
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Nov 22 14:13:26 CST 2011
Replace your prior implementation of bar() with this, and you then have a reall array solution (workaround) until the @filenames() bug is fixed:
app ( file result ) barapp ( file files[], string s[])
   ls "-lt" s stdout=@result;
(file result) bar (file files[] )
  string s[];
  foreach f, i in files {
    s[i] = @filename(f);
  result = barapp( files, s );
- Mike
----- Original Message -----
> From: "Mark Hereld" <hereld at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "swift-devel" <swift-devel at ci.uchicago.edu>, "Thomas D. Uram" <turam at mcs.anl.gov>
> Sent: Tuesday, November 22, 2011 1:07:32 PM
> Subject: Re: arrays of files
> thanks mike! only interested in the array solution. collecting
> generic patterns that can be easily reused for wide number of
> situations. gpsi. -- mark
> On Nov 22, 2011, at 12:05 PM, Michael Wilde wrote:
> Yup, thanks, Mark - its a bug.
> if you change the body of bar to read:
> ls "-lt" @filename(files[0]) @filename(files[1]) stdout=@result;
> instead of:
> ls "-lt" @filenames(files) stdout=@result;
> then it works.
> I'll file a bugzilla ticket on this. David, can you add to the test
> suite? Mihael, can you fix it?
> Thanks,
> - Mike
> From: "Mark Hereld" < hereld at mcs.anl.gov >
> To: "Michael Wilde" < wilde at mcs.anl.gov >
> Cc: "Thomas D. Uram" < turam at mcs.anl.gov >
> Sent: Tuesday, November 22, 2011 11:48:17 AM
> Subject: arrays of files
> Mike,
> this swift seems to compile without complaint but breaks down
> with a null pointer at the last line (invocation of "bar"). i think
> i'm
> confused about arrays of file objects. ideas?
> type file; app ( file result ) foo ( string args[] ) { ls "-lt" args
> stdout=@result; } app ( file result ) bar ( file files[] ) { ls "-lt"
> @filenames(files) stdout=@result; } file out <"dirlisting.txt">; out =
> foo([".",".."]); file out2 <"nother.txt">; out2 = foo(["/"]); file
> out3 <"proof.txt">; out3 = bar([out,out2]);
> Mark Hereld < hereld at mcs.anl.gov >
> Senior Fellow - Computation Institute
> Experimental Systems Engineer - Mathematics and Computer Science
> Visualization and Analysis Lead - Argonne Leadership Computing
> Facility
> Argonne National Laboratory
> The University of Chicago
> Cell: 630.327.2088
> Voice: 630.252.4170
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Facility
> Cell: 630.327.2088
> Voice: 630.252.4170
Michael Wilde
