[Swift-devel] Issues in worker-side GridFTP
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Nov  3 09:42:57 CDT 2011
On Tue, Nov 1, 2011 at 8:46 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> We have been discussing the feasibility of adding a data management option
> to Swift that performs data transfer via globus-url-copy from the worker
> node, likely issued from within a CDM function.
> This is mainly intended for OSG sites where no other straightforward
> transfer option exists (e.g. on sites that have storage servers like
> SRM-DCache and no mounted access to the primary GridFTP server's
> filesystem).
> I'm wondering how worker-side GridFTP will work with respect to data
> management functions like creation of the work directory, job directory,
> and transfer of utility files like swiftwrap etc.
> Any ideas on how best to do this? Its almost like we should first try this
> in coasters using provider staging, where we start by replacing the data
> transfer with a worker-side invocation of guc.
> Mihael, is this something that you could do for us?  If you could create a
> test version of this using a simple "cp" in a worker.pl callout script
> for doing data transfer, we could then do the testing with actual guc.
I can start working on this. Will keep posted as and when I have questions
or need help debug.
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111103/3e9ca033/attachment.html>
