[Swift-devel] Re: coaster-service -passive null pointer exception
David Kelly
davidkelly999 at gmail.com
Wed May 25 11:44:17 CDT 2011
Hey Mihael,
I was testing my script a little more today and ran into some errors related
to CONFIGSERVICE. In this example I was testing passive mode but manually
specifying ports instead of using the port files. I'm not sure if that makes
a difference - I included an output of ps so you could see how each of the
apps were being called. There is more detail in the swift log and in
logs/coaster.log.
David
On Tue, May 24, 2011 at 2:27 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Sorry about that. Attempt #2 is in svn.
> Mihael
> On Tue, 2011-05-24 at 14:15 -0500, David Kelly wrote:
> > Thanks. I gave it a try and this is what I am seeing now:
> > Failed to connect: Connection refused at /home/davidk/work/worker.pl
> > line 300.
> > from coaster.log:
> > Error starting coaster service: null
> > java.lang.NullPointerException
> > at
> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:145)
> > David
> > On Tue, May 24, 2011 at 1:57 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> > I committed a tentative fix to trunk. I won't swear by it, but
> > please
> > give it a try and let me know how it works.
> > Mihael
> > On Tue, 2011-05-24 at 13:44 -0500, David Kelly wrote:
> > > Attached is the coaster.log that is being generated, but it
> > doesn't
> > > contain much information.
> > > But where it was throwing the exception, I called
> > getStrackTrace() to
> > > get more info and saved it. Hope this helps:
> org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.nextId(JobQueue.java:122)
> org.globus.cog.abstraction.coaster.service.LocalTCPService.registrationReceived(LocalTCPService.java:58)
> org.globus.cog.abstraction.coaster.service.local.RegistrationHandler.requestComplete(RegistrationHandler.java:41)
> org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
> org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:390)
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:158)
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Multiplexer.run(AbstractStreamKarajanChannel.java:377)
> > > David
> > > On Tue, May 24, 2011 at 12:47 PM, Mihael Hategan
> > > wrote:
> > > Do you have logs or exact stack trace for this?
> > > On Tue, 2011-05-24 at 10:21 -0500, David Kelly
> > wrote:
> > > > Hello,
> > > > When trying to run coaster-service in passive
> > mode, I get a
> > > null
> > > > pointer exception when starting worker nodes. This
> > seems to
> > > happen
> > > > when the worker node tries to register with the
> > coaster
> > > service. I
> > > > get:
> > > > Failed to process data: Failed to register
> > (service returned
> > > error:
> > > > java.lang.NullPointerException)
> > > at /home/davidk/work/worker.pl line
> > > > 762.
> > > > The exception gets thrown from
> > RegistrationHandler.java.
> > > Running a
> > > > swift script before starting the workers seems to
> > be the
> > > workaround..
> > > > but I think with the -passive option we shouldn't
> > need to do
> > > that
> > > > anymore, is that correct?
> > > > Thanks,
> > > > David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110525/137e2f31/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110525/137e2f31/attachment.bin>
