[Swift-devel] Re: coaster-service -passive null pointer exception
Mihael Hategan
hategan at mcs.anl.gov
Tue May 24 14:27:39 CDT 2011
Sorry about that. Attempt #2 is in svn.
Mihael
On Tue, 2011-05-24 at 14:15 -0500, David Kelly wrote:
> Thanks. I gave it a try and this is what I am seeing now:
> Failed to connect: Connection refused at /home/davidk/work/worker.pl
> line 300.
> from coaster.log:
> Error starting coaster service: null
> java.lang.NullPointerException
> at
> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:145)
> David
> On Tue, May 24, 2011 at 1:57 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> I committed a tentative fix to trunk. I won't swear by it, but
> please
> give it a try and let me know how it works.
> Mihael
> On Tue, 2011-05-24 at 13:44 -0500, David Kelly wrote:
> > Attached is the coaster.log that is being generated, but it
> doesn't
> > contain much information.
> > But where it was throwing the exception, I called
> getStrackTrace() to
> > get more info and saved it. Hope this helps:
> org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.nextId(JobQueue.java:122)
> org.globus.cog.abstraction.coaster.service.LocalTCPService.registrationReceived(LocalTCPService.java:58)
> org.globus.cog.abstraction.coaster.service.local.RegistrationHandler.requestComplete(RegistrationHandler.java:41)
> org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
> org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:390)
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:158)
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Multiplexer.run(AbstractStreamKarajanChannel.java:377)
> > David
> > On Tue, May 24, 2011 at 12:47 PM, Mihael Hategan
> > wrote:
> > Do you have logs or exact stack trace for this?
> > On Tue, 2011-05-24 at 10:21 -0500, David Kelly
> wrote:
> > > Hello,
> > > When trying to run coaster-service in passive
> mode, I get a
> > null
> > > pointer exception when starting worker nodes. This
> seems to
> > happen
> > > when the worker node tries to register with the
> coaster
> > service. I
> > > get:
> > > Failed to process data: Failed to register
> (service returned
> > error:
> > > java.lang.NullPointerException)
> > at /home/davidk/work/worker.pl line
> > > 762.
> > > The exception gets thrown from
> RegistrationHandler.java.
> > Running a
> > > swift script before starting the workers seems to
> be the
> > workaround..
> > > but I think with the -passive option we shouldn't
> need to do
> > that
> > > anymore, is that correct?
> > > Thanks,
> > > David
