[Swift-devel] coaster-service -passive null pointer exception
    David Kelly
    davidkelly999 at gmail.com
    Tue May 24 10:21:22 CDT 2011
Hello,
When trying to run coaster-service in passive mode, I get a null pointer
exception when starting worker nodes. This seems to happen when the worker
node tries to register with the coaster service. I get:
Failed to process data: Failed to register (service returned error:
java.lang.NullPointerException) at /home/davidk/work/worker.pl line 762.
The exception gets thrown from RegistrationHandler.java. Running a swift
script before starting the workers seems to be the workaround.. but I think
with the -passive option we shouldn't need to do that anymore, is that
correct?
David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110524/ca573573/attachment.html>
