[Swift-devel] recent error on beagle
    Glen Hocky
    hockyg at uchicago.edu
    Sat May 21 12:45:25 CDT 2011
Thanks for looking, nothing has changed except some of the actual
python script that is running, but that appears to be working b/c the
simulation is generating output files.
All run stuff for this job are
/home/hockyg/reichman/glassy_dynamics/code/swift_pySimulate3/run/final/glassRunSizeSwitching-20110521-0832-zdruneuf.*
all files like tc and sites can be found with
ls /home/hockyg/reichman/glassy_dynamics/code/swift_pySimulate3/run/final/*20110521-0832*
On Sat, May 21, 2011 at 1:40 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Glen, I dont recognize it - need to dig deeper.
> Where can we find all the files (.swift, tc, sites, properties) and command line?
> You should try module load swift - thats the official 0.92.1 for Beagle.
> (But its possible the same as you are running here).
> When did this last work for you?  Anything change in sites params?
> - Mike
>> Does anyone know what this error means? It just started happening on
>> beagle + coasters
>> Swift log attached
>> Swift version is Mike's:
>> /home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift
>> Thanks
>> Glen
>> Progress: Active:48
>> Progress: Active:48
>> queuedsize > 0 but no job dequeued. Queued: {}
>> java.lang.Throwable
>> at
>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>> at
>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>> at
>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>> java.lang.Throwable
>> at
>> at
>> at
>> Progress: Active:47 Failed but can retry:1
>> Shutting down worker
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
