[Swift-devel] recent trunk changes swift parsing
Mihael Hategan
hategan at mcs.anl.gov
Fri May 20 15:31:28 CDT 2011
Can you post a stack trace or a pointer to the log?
On Fri, 2011-05-20 at 15:14 -0500, ketan wrote:
> I updated trunk and seems swift parsing has changed a bit?
> I see this:
> Swift svn swift-r4502 cog-r3128 (cog modified locally)
> RunID: 20110520-2005-kst5ztsf
> Progress: time: Fri, 20 May 2011 20:05:51 +0000
> SwiftScript trace: str_roots.[0]:string = 3lyv-4 - Closed
> Execution failed:
> For input string: "3.0"
> for my this swift:
> type file_pdb;
> type file_dat;
> app (file_dat dat_file)
> do_one_dock(
> string param_root,
> string param_modulo,
> file_pdb param_file_static,
> file_pdb param_file_mobile )
> modftdock 32
> "-modulo" @param_modulo
> "-root" @param_root
> "-static" @param_file_static
> "-mobile" @param_file_mobile
> "-calculate_grid" @arg("grid","2.5")
> "-angle_step" "10"
> "-keep" "10"
> "-noelec";
> string modulus = @arg("m","100");
> string str_roots[] = readData( @arg( "list" ) );
> foreach str_root in str_roots
> trace( str_root );
> string str_file_static = @strcat( "input/", str_root, ".pdb" );
> string str_file_mobile = "input/4TRA.pdb";
> file_pdb file_static < single_file_mapper; file = str_file_static >;
> file_pdb file_mobile < single_file_mapper; file = str_file_mobile >;
> file_dat dat_files[] < simple_mapper;
> padding = 3,
> location = "output",
> prefix = @strcat( str_root, "_" ),
> suffix = ".dat" >;
> // break docking jobs + do 'em in parallel
> int n = @toint(@arg("n","1"));
> foreach mod_index in [0:n-1]
> string str_modulo = @strcat(mod_index, ":", modulus);
> dat_files[ mod_index ] = do_one_dock( str_root,
> str_modulo,
> file_static,
> file_mobile );
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
