[Swift-devel] DataNode.toString()
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue May 17 17:51:06 CDT 2011
Indeed. I committed a fix to unwrap swift data when passing values to
execute() (stdin, out, err, and the arguments in particular).
I don't think toString() should be "overloaded" like it was.
On Tue, 2011-05-17 at 16:56 -0500, Justin M Wozniak wrote:
> I think this change affects arguments to apps:
> type file;
> (file f) echo (int i) {
> app { echo i stdout=@f; }
> int greetings = 2;
> file hw = echo(greetings);
> DEBUG vdl:execute2 JOB_START jobid=echo-tnyfi9ak tr=echo
> arguments=[greetings:int = 2.0 - Closed]
> On Fri, 13 May 2011, Mihael Hategan wrote:
> > I changed that in trunk. It used to be:
> > org.griphyn.vdl.mapping.RootDataNode identifier
> > dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
> > dataset=sgt_var (not closed)
> > That was annoying, noisy, and I had no idea what's what.
> > It is now:
> > name:type = value - [Open/Closed]
> > The provenance data should still be the same, but it may not. So please
> > let me know if anything breaks.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
