[Swift-devel] Re: sites.xml settings for Beagle in Swift trunk?
    ketan
    ketan at mcs.anl.gov
    Fri May  6 14:55:36 CDT 2011
Please find attached the correct sites.xml template for trunk version of
coasters-PBS provider.
Ketan
On 5/6/11 12:00 PM, Michael Wilde wrote:
> So that others can test as well, could you post the latest recommended sites.xml settings for *trunk code* for Beagle?
> How will we help users change from the current sites settings in use for the 0.92-branch Beagle-support mods to the new trunk settings when that goes live in 0.93?
> Will gensites be able to help us with the transition?
> Thanks,
> Mike
>> On 5/6/11 11:35 AM, Michael Wilde wrote:
>>> Ketan, Justin,
>>> Did you work out yesterday the right sites.xml settings for
>>> Coasters-PBS-Cray-aprun?
>>> I think this page was the start of your documentation for those,
>>> Justin:
>>>     https://sites.google.com/site/swiftdevel/internals/providers/coasters-provider
>>> Ketan, can you move these to the new cookbook, and work out any
>>> issues to make sure they are correct?
>>> Did you both determine that the trunk code is working OK, or that it
>>> has bugs that still prevent it from running correctly on Beagle?
>> I tested yesterday with the trunk code on beagle with new coaster-site
>> attributes and this bug is not in anymore.
>> However, testing the trunk code on a large run is still not concluded.
>> I
>> will report as soon as a big run gets underway on beagle.
>>> Thanks,
>>> - Mike
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110506/bd4b261e/attachment.xml>
