[Swift-devel] CDM
    Michael Wilde
    wilde at mcs.anl.gov
    Thu May  5 10:34:39 CDT 2011
We should in the interim work up a cookbook entry for CDM.
I suspect we can start with the example of how we use cdm DIRECT for modftdock on beagle.  I suspect thats what you want, Tim?
For this, we used following rule in file "cdm":
rule .* DIRECT /lustre/beagle/wilde/mp/run04
...and added the option "-fs.file cdm" to the swift command line.
(where run04 was the directory I ran the swift command from, and below which the scripts input and output files resided. The files were mapped to relative paths, and the DIRECT rule instructed swift to bypass staging of files to/from the work directory.
- Mike
----- Original Message -----
> Hi Tim
> I'm out of town today and tomorrow but I'll check on this when I'm
> back. CDM broadcast is only designed for the BG/P, but we could plug
> in
> support for other systems if there is an available broadcast
> mechanism.
> Justin
> On Thu, 5 May 2011, Tim Armstrong wrote:
> > Hi All,
> >  I'm looking at trying to use collective data management to
> >  broadcast some
> > shared data files for SwiftR. I have found the CDM section in the
> > swift
> > user guide, but are there any additional resources to help me
> > understand how
> > CDM in swift works?
> > - Tim
> Justin M Wozniak
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
