[Swift-devel] Re: bug-zilla import
    Jonathan Monette
    jon.monette at gmail.com
    Thu Mar 31 17:40:33 CDT 2011
Don't worry about it.  I believe I am the only that uses this so it's fine.
 Glad it's getting use now.
On Thu, Mar 31, 2011 at 5:39 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> That certainly does, in large part, Jon!
> I'm cc'ing John Dennis here and I apologize to you for my forgetfullness!
> We need to get this into the User Guide (along with the other built in
> functions that you and Justin and others added)
> Nice piece of development work!
> - Mike
> > Sent that a bit early.
> > The INCLUDEPATH variable is SWIFT_LIB. export
> > SWIFT_LIB="/home/user/Swift_files" and then do import "hello". It will
> > check relatively for hello.swift and if its not there it will then
> > check the SWIFT_LIB variable. Doesn't that satisfy the bug-zilla
> > report?
> > On Thu, Mar 31, 2011 at 5:32 PM, Jonathan Monette <
> > jon.monette at gmail.com > wrote:
> > Mike,
> > The bug-zilla report you just filed on the import, doesn't it do most
> > of that already? I had added modifications during the summer to
> > improve import a bit. You can do import "test/test_script" and it will
> > import test_script from the test directory relative to the calling
> > script. The INCLUDEPATH
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
> > direction.
> > - Albert Einstein
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110331/05b999ea/attachment.html>
