[Swift-devel] duplicated job submission in swift-0.92?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Mar 31 13:52:34 CDT 2011
We decided the following:
- I will revert the changes in the 0.92 branch
- re-commit bug fixes that were committed after the merge
- merge the 0.92 branch to trunk
- fix the problems in trunk
One issue that came up was the exact "workflow" in the
branching/releasing/merging. I think we discussed this previously on
this mailing list, and it may just be that Sarah has made a wiki page
about it. But I'll summarize:
- before a release, trunk is branched into a release branch
- heavy development may continue in trunk while the branch only sees bug
fixes
- after the release, the branch is merged back to trunk (so that bug
fixes in the branch make it back to trunk)
- rinse and repeat
Mihael
On Thu, 2011-03-31 at 13:35 -0500, Justin M Wozniak wrote:
> Sure: (630) 252-3351
> On Thu, 31 Mar 2011, Mihael Hategan wrote:
> > Can we have a quick phone chat about this?
> > On Thu, 2011-03-31 at 12:48 -0500, Justin M Wozniak wrote:
> >> By doing a bisection I found that the regression seems to occur in Swift
> >> trunk between 3835:3836 (around 01/01/2011).  Still looking...
> >> On Wed, 30 Mar 2011, Mihael Hategan wrote:
> >>> On Wed, 2011-03-30 at 22:12 -0500, Michael Wilde wrote:
> >>>> ----- Original Message -----
> >>>>> Why was trunk merged into the stable branch?
> >>>> Can you clarify what you mean here?
> >>> Cog trunk was merged into cog branch 4.1.8 which corresponds to swift
> >>> 0.92.
> >>>> Trunk merged into *what* stable branch, when?
> >>>> Do you mean before 0.92 was generated, or after?
> >>> After. The 0.92 branch contains code from trunk that was added to trunk
> >>> after 0.92 was merged. In particular 0.92 was, I think, not supposed to
> >>> contain stuff from the fast branch and it does.
> >>>> Is 0.92 not tagged?
> >>> It's a branch.
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
