[Swift-devel] duplicated job submission in swift-0.92?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Mar 31 12:03:51 CDT 2011
I think that was in the reverse direction. The branch needs to go into
trunk and not the other way around.
Mihael
On Thu, 2011-03-31 at 09:34 -0500, Justin M Wozniak wrote:
> I did that to get things unified in trunk.  I can revert things back to
> the state before that if you think it would help sort this out.
> On Wed, 30 Mar 2011, Mihael Hategan wrote:
> > Why was trunk merged into the stable branch?
> > On Wed, 2011-03-30 at 18:40 -0700, Mihael Hategan wrote:
> >> On Wed, 2011-03-30 at 20:37 -0500, Michael Wilde wrote:
> >>> OK, what am I missing?
> >> Nothing. That shouldn't be happening.
> >> Here's what (approximately) you should get:
> >> Swift svn swift-r3526 (swift modified locally) cog-r656 (cog modified
> >> locally)
> >> RunID: 20110330-1839-y71gls4a
> >> Progress:  time:0
> >> [Misc] WARN  pool-1-thread-4  - SwiftScript trace: for, 2
> >> [Misc] WARN  pool-1-thread-1  - SwiftScript trace: for, 1
> >> Final status:  time:54
> >>> int arr[];
> >>> arr[0]=1;
> >>> arr[1]=2;
> >>> foreach a in arr {
> >>>   trace("for", a);
> >>> login1$ swift zz3.swift
> >>> Swift svn swift-r4157 cog-r3056
> >>> RunID: 20110331-0134-bfzhkgaa
> >>> Progress:
> >>> Final status:
> >>> When did the foreach loop become the twice-each loop?
> >>> I need to try some other revision and hosts with this.
> >>> - Mike
> >>> ----- Original Message -----
> >>>> Wow, I didn't know we can do that! I treat the docs too canonically :P
> >>>> 2011/3/30 Michael Wilde <wilde at mcs.anl.gov>:
> >>>>> login1$ cat zz2.swift
> >>>>> foreach a in [0:3] {
> >>>>>  trace("for", a);
> >>>>> login1$ swift zz2.swift
> >>>>> RunID: 20110331-0057-huo8jei0
> >>>>> Progress:
> >>>>> SwiftScript trace: for, 3
> >>>>> SwiftScript trace: for, 0
> >>>>> Final status:
> >>>>> login1$
> >>>>> I suspect we need to make this more clear in the user guide and
> >>>>> tutorials :)
> >>>> I agree.
> >>>>> - Mike
> >>>>>> Or just use the concurrent mapper to let swift handle the output
> >>>>>> naming itself. The resume files can't persist through multiple
> >>>>>> sessions though.
> >>>>>>> The most common case for this error occurs when two iterations
> >>>>>>> within a foreach loop map an output file to the same physical
> >>>>>>> file
> >>>>>>> name. When swift runs and tries to put the output object into its
> >>>>>>> site cache, it sees that a file of the name name is already in
> >>>>>>> the
> >>>>>>> cache, and its semantics do not allow that.
> >>>>>>> I have not yet stared at this code long enough to see if this
> >>>>>>> explains what is happening here.
> >>>>>>> I also dont know why it might work under one version and fail
> >>>>>>> under
> >>>>>>> 0.92. If the above situation is occurring, perhaps there is some
> >>>>>>> randomness involved: loop iteration ordering; filename generation
> >>>>>>> randomness or difference, etc.
> >>>>>>> But I would debug with that in mind: make sure that all *output*
> >>>>>>> fie
> >>>>>>> names mapped by the script are unique. Ideally, one should be
> >>>>>>> able
> >>>>>>> to find the culprit by grepping the swift log for all the mapped
> >>>>>>> file names and look for duplicates.
> >>>>>>> - Mike
> >>>>>>>> Or maybe local variables are static? Maybe they mapped to
> >>>>>>>> different
> >>>>>>>> files but to the same cache object? But I have been doing local
> >>>>>>>> variables in my own workflows though.
> >>>>>>>> 2011/3/30 Jonathan Monette <jon.monette at gmail.com>:
> >>>>>>>>> Ok. I understand this error better. But shouldn't that be a
> >>>>>>>>> different
> >>>>>>>>> error then? Like a and b are mapped to the same file? I don't
> >>>>>>>>> know
> >>>>>>>>> if Swift
> >>>>>>>>> can know this but looking at the explanation and error it
> >>>>>>>>> should
> >>>>>>>>> unless this
> >>>>>>>>> cache message has a deeper meaning.
> >>>>>>>>> On Wed, Mar 30, 2011 at 6:21 PM, Allan Espinosa
> >>>>>>>>> <aespinosa at cs.uchicago.edu>
> >>>>>>>>> wrote:
> >>>>>>>>>> I had this error before when two output mapper objects mapped
> >>>>>>>>>> to
> >>>>>>>>>> the same
> >>>>>>>>>> file.
> >>>>>>>>>> $ swift bug_same.swift
> >>>>>>>>>> Swift svn swift-r4208 cog-r3073
> >>>>>>>>>> RunID: 20110330-1818-ygec7ppa
> >>>>>>>>>> Progress: time:0
> >>>>>>>>>> The cache already contains
> >>>>>>>>>> localhost:bug_same-20110330-1818-ygec7ppa/shared/foo.
> >>>>>>>>>> Progress: time:1960 Stage in:1 Finished successfully:1
> >>>>>>>>>> [aespinosa at communicado testing]$
> >>>>>>>>>> [aespinosa at communicado testing]$ cat bug_same.swift
> >>>>>>>>>> type file;
> >>>>>>>>>> app (file out) echo(string input) {
> >>>>>>>>>>  echo input stdout=@filename(out);
> >>>>>>>>>> file a <"foo">;
> >>>>>>>>>> file b <"foo">;
> >>>>>>>>>> a = echo("hello world");
> >>>>>>>>>> b = echo("foo bar");
> >>>>>>>>>> But i think you should be using other Swift mappers that does
> >>>>>>>>>> auto-numbering of files by default.
> >>>>>>>>>> -Allan
> >>>>>>>>>> 2011/3/30 Zhao Zhang <zhaozhang at uchicago.edu>:
> >>>>>>>>>>> Hi guys,
> >>>>>>>>>>> I am seeing something weird in swfit-0.92. Any idea about
> >>>>>>>>>>> this?
> >>>>>>>>>>> The swift script is very simple:
> >>>>>>>>>>> zzhang at sandbox:~/workplace/Andrey> cat movies.swift
> >>>>>>>>>>> type Pickle {}
> >>>>>>>>>>> type History {}
> >>>>>>>>>>> type Image {}
> >>>>>>>>>>> app (History historyout) movie_graph (int rerun, int
> >>>>>>>>>>> epochs,
> >>>>>>>>>>> Pickle
> >>>>>>>>>>> picklefile)
> >>>>>>>>>>>   movie_graph rerun epochs;
> >>>>>>>>>>> int arr[];
> >>>>>>>>>>> iterate i
> >>>>>>>>>>>  arr[i] = i+1;
> >>>>>>>>>>> }until(i == 1);
> >>>>>>>>>>> int epochs;
> >>>>>>>>>>> epochs = 3;
> >>>>>>>>>>> Pickle picklefile <single_file_mapper;
> >>>>>>>>>>> file="for_movies.pickled">;
> >>>>>>>>>>> foreach a in arr{
> >>>>>>>>>>>  History historyout <single_file_mapper;
> >>>>>>>>>>>  file=@strcat("output/rerun", a,
> >>>>>>>>>>> "/histories.pickled-", a)>;
> >>>>>>>>>>>  historyout = movie_graph(a, epochs, picklefile);
> >>>>>>>>>>> I ran the script with the latest 0.92 version, which is
> >>>>>>>>>>> loaded
> >>>>>>>>>>> as
> >>>>>>>>>>> a
> >>>>>>>>>>> module
> >>>>>>>>>>> on beagle. The I saw this:
> >>>>>>>>>>> zzhang at sandbox:~/workplace/Andrey> swift -tc.file ./tc.data
> >>>>>>>>>>> movies.swift
> >>>>>>>>>>> Variable epochs defined in scope 99878388 shadows variable
> >>>>>>>>>>> of
> >>>>>>>>>>> same name
> >>>>>>>>>>> in
> >>>>>>>>>>> scope 1813605401
> >>>>>>>>>>> Variable picklefile defined in scope 99878388 shadows
> >>>>>>>>>>> variable
> >>>>>>>>>>> of
> >>>>>>>>>>> same
> >>>>>>>>>>> name
> >>>>>>>>>>> in scope 1813605401
> >>>>>>>>>>> RunID: 20110330-1636-ev8vm8gb
> >>>>>>>>>>> Progress:
> >>>>>>>>>>> Progress: Selecting site:3 Active:1
> >>>>>>>>>>> Progress: Selecting site:3 Checking status:1
> >>>>>>>>>>> Progress: Selecting site:2 Stage in:1 Finished
> >>>>>>>>>>> successfully:1
> >>>>>>>>>>> Progress: Selecting site:2 Active:1 Finished successfully:1
> >>>>>>>>>>> Progress: Selecting site:1 Stage in:1 Finished
> >>>>>>>>>>> successfully:2
> >>>>>>>>>>> Progress: Selecting site:1 Active:1 Finished successfully:2
> >>>>>>>>>>> Progress: Selecting site:1 Checking status:1 Finished
> >>>>>>>>>>> successfully:2
> >>>>>>>>>>> localhost:movies-20110330-1636-ev8vm8gb/shared/output/rerun1/histories.pickled-1.
> >>>>>>>>>>> Execution failed:
> >>>>>>>>>>> Then I switched to an older version, it worked well.
> >>>>>>>>>>> movies.swift
> >>>>>>>>>>> Variable epochs defined in scope 212602028 shadows variable
> >>>>>>>>>>> of
> >>>>>>>>>>> same name
> >>>>>>>>>>> in
> >>>>>>>>>>> scope 1538939834
> >>>>>>>>>>> Variable picklefile defined in scope 212602028 shadows
> >>>>>>>>>>> variable
> >>>>>>>>>>> of same
> >>>>>>>>>>> name
> >>>>>>>>>>> in scope 1538939834
> >>>>>>>>>>> Swift svn swift-r3291 (swift modified locally) cog-r2750
> >>>>>>>>>>> (cog
> >>>>>>>>>>> modified
> >>>>>>>>>>> locally)
> >>>>>>>>>>> RunID: 20110330-1639-gmbyz1qa
> >>>>>>>>>>> Progress:
> >>>>>>>>>>> Progress: Active:2
> >>>>>>>>>>> Progress: Active:1 Checking status:1
> >>>>>>>>>>> Final status: Finished successfully:2
> >>>>>>>>>> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
