[Swift-devel] duplicated job submission in swift-0.92?
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Mar 31 00:16:31 CDT 2011
Kets, lets discuss in person tomorrow.  If this is the one you have been running, its very possible that you are running all your app() calls entirely on the login node, as without my mods Swift jobs do not do aprun().
Only my version of the code in /home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift has the logic to run correctly on Beagle.
I thought that *this* is what you put into the swift module on Beagle.
If not, take a look at the difference in .submit files generated by plain 0.92 vs the revision above.
We need to find a way to get this into svn: either into a new working trunk, or some branch based on 0.92 (eg 0.92cray?)
- Mike
----- Original Message -----
> Mike,
> I have no idea about ppn:N:cray compilation enhancement. I put the
> latest, stable version *assuming* it is fit for beagle environment.
> Partly based on my knowledge that it has been working on BG/P
> environment.
> Ketan
> On Mar 30, 2011, at 11:33 PM, Michael Wilde wrote:
> > Ketan, is the swift module on Beagle, then, compiled without the
> > ppn:N:cray enhancement? If so, it could not be working on Cray
> > compute nodes, could it?
> > - Mike
> >> Hello,
> >> Just a note that the installation on beagle from which Zhao
> >> originally
> >> reported this issue is installed from a precompiled binary.
> >> Following
> >> are my notes from the installation:
> >> Downloaded precompiled binary.
> >> Version: 0.92
> >> Date: March 24, 2011 at 3.00 PM
> >> from the url:
> >> http://www.ci.uchicago.edu/swift/packages/swift-0.92.tar.gz
> >> Created a symlink called default@ to this location
> >> Also found at /soft/swift/0.92/notes.txt on beagle.
> >> Regards,
> >> Ketan
> >> On Mar 30, 2011, at 10:21 PM, Mihael Hategan wrote:
> >>>>> Why was trunk merged into the stable branch?
> >>>> Can you clarify what you mean here?
> >>> Cog trunk was merged into cog branch 4.1.8 which corresponds to
> >>> swift
> >>> 0.92.
> >>>> Trunk merged into *what* stable branch, when?
> >>>> Do you mean before 0.92 was generated, or after?
> >>> After. The 0.92 branch contains code from trunk that was added to
> >>> trunk
> >>> after 0.92 was merged. In particular 0.92 was, I think, not
> >>> supposed
> >>> to
> >>> contain stuff from the fast branch and it does.
> >>>> Is 0.92 not tagged?
> >>> It's a branch.
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
