[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Mon Mar 28 09:34:45 CDT 2011
Hi Mihael, Mike,
I think Mike had built a local Swift with pbs+coaster capabilities for
beagle. I am not sure if a clean install from repo has (if yes, I do not
know which rev) these capabilities.
Ketan
On Mon, Mar 28, 2011 at 2:04 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> The IBM implementation seems to do pretty much the same thing as the Sun
> one. Which is that they never call .cancel() on a timer.
> So I don't understand what's happening here. I don't see any piece of
> code that cancels that timer. Are you all using the same swift
> installation? Can you try a clean install?
> Mihael
> On Sun, 2011-03-27 at 20:12 -0500, Ketan Maheshwari wrote:
> > On Sun, Mar 27, 2011 at 4:23 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         Actually I'm not so sure any more.
> >         My java Timer does not seem to have a scheduleImpl method.
> >         What version
> >         of java is this?
> > On beagle it is java 1.6.0:
> > [ketan at login2:~]$ java -version
> > java version "1.6.0"
> > Java(TM) SE Runtime Environment (build pxa6460sr9-20101125_01(SR9))
> > IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Linux amd64-64
> > jvmxa6460sr9-20101124_69295 (JIT enabled, AOT enabled)
> > J9VM - 20101124_069295
> > JIT  - r9_20101028_17488ifx2
> > GC   - 20101027_AA)
> > JCL  - 20101119_01
> > --Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110328/ad139b14/attachment.html>
