[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Mar 27 15:58:12 CDT 2011
Thank you good sir!
It seems that the problem occurs when the system is shutting down.
During JVM finalization it turns out that timers cannot be used. When
they are, the "Timer was cancelled" error appears.
I'll see how this can be fixed.
On Sun, 2011-03-27 at 15:49 -0500, Michael Wilde wrote:
> On CI net, in /home/wilde/swift/lab, you can find "logs. Logs please. Logs!!!" :)
> login1$ grep -i 'timer.*cancel' catsn*.log
> catsn-20110320-2218-tjaeo8md.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110320-2231-o3tft91h.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110320-2257-tpoi32je.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110320-2258-02gmt2c7.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110320-2258-2ued34uf.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110321-1600-3j1159na.log:java.lang.IllegalStateException: Timer was cancelled
> catsn-20110324-1026-x6yxif12.log:java.lang.IllegalStateException: Timer was cancelled
> login1$
> > Ok. I need logs. Logs please. Logs!!!
> > On Sat, 2011-03-26 at 02:26 -0700, Mihael Hategan wrote:
> > > I will look at it on Sunday or Monday.
> > > Mihael
> > > On Sat, 2011-03-26 at 00:28 -0500, Ketan Maheshwari wrote:
> > > > Hi,
> > > > The timer error: "Timer was cancelled" persists on beagle. Does
> > > > anybody been able to resolve it so far?
> > > > The stack I got today is quite similar to the previous ones:
> > > > Got exception in send
> > > >     at java.util.Timer.scheduleImpl(Timer.java:564)
> > > >     at java.util.Timer.schedule(Timer.java:449)
> > > >     at
> > > > org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
> > > >     at
> > > > org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
> > > >     at
> > > > org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
> > > >     at
> > > > $Sender.run(AbstractPipedChannel.java:115)
> > > >     at
> > > >     at
> > > >     at
> > > >     at
> > > >     at
> > > >     at
> > > >     at
> > > > org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
> > > > Canceling job 21995.sdb
> > > > Ketan
> > > > On Mon, Mar 21, 2011 at 6:33 PM, Mihael Hategan
> > > > <hategan at mcs.anl.gov>
> > > > wrote:
> > > >         So it is related to PBS. Please send me logs with this
> > > >         problem. The
> > > >         timer thing shouldn't be happening.
> > > >         On Mon, 2011-03-21 at 17:30 -0400, Glen Hocky wrote:
> > > >         > I got rid of the problem by setting my project as per
> > > >         > Ti's
> > > >         > instructions
> > > >         > projects --available
> > > >         > projects --set PROJECT
> > > >         > On Mon, Mar 21, 2011 at 4:44 PM, Mihael Hategan
> > > >         > wrote:
> > > >         >         On Mon, 2011-03-21 at 13:23 -0500, Michael Wilde
> > > >         wrote:
> > > >         >         > Mihael, all, do you have any thoughts on what
> > > >         >         > that
> > > >         might be?
> > > >         >         Yes, but what I think it is wouldn't (in any
> > > >         >         obvious
> > > >         way I can
> > > >         >         see) be
> > > >         >         influenced by changes in the environment.
> > > >         >         If you look at the logs, is there anything else
> > > >         suspicious
> > > >         >         going on?
> > > >         >         Mihael
> > > >         >         _______________________________________________
> > > >         >         Swift-devel mailing list
> > > >         >         Swift-devel at ci.uchicago.edu
> > > >         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
