[Swift-devel] hanging problem
Jonathan Monette
jon.monette at gmail.com
Wed Mar 23 16:31:15 CDT 2011
I think I have figured out my problem. Here is the function it hangs in.
( Table fits_tbl ) mFitBatch( Image diff_imgs[], Table diff_tbl )
Status stats[] <structured_regexp_mapper; source = diff_imgs, match =
".*\\/(.*)", transform = "stat_dir/stat.\\1">;
Table status_tbl = create_status_table( diff_tbl );
foreach img, i in stats
stats[ i ] = mFitplane ( diff_imgs[i] );
fits_tbl = mConcatFit( status_tbl, stats );
The app mConcatFit never executes. Here is the app.
app ( Table fits_tbl ) mConcatFit( Table status_tbl, Status stats[] )
mConcatFit @status_tbl @fits_tbl @dirname( stats[0] );
The problem is @dirname(stats[0]) returns an
org.griphyn.vdl.karajan.VDL2FutureException. When I do a tracef( "%s\n",
@dirname(stats[0]) ) that is what gets printed to the screen. This causes
the script to hang. When I do a tracef( "%q\n", stats ) this is the output.
[org.griphyn.vdl.mapping.DataNode identifier
dataset:20110323-1620-9e0zjb30:720000000602 type Status with no value at
dataset=stats path=[0] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000601 type Status with no
value at dataset=stats path=[1] (not
closed),org.griphyn.vdl.mapping.DataNode identifier
dataset:20110323-1620-9e0zjb30:720000000599 type Status with no value at
dataset=stats path=[2] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000598 type Status with no
value at dataset=stats path=[3] (not
dataset:20110323-1620-9e0zjb30:720000000606 type Status with no value at
dataset=stats path=[4] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000605 type Status with no
value at dataset=stats path=[5] (not
dataset:20110323-1620-9e0zjb30:720000000604 type Status with no value at
dataset=stats path=[6] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000603 type Status with no
value at dataset=stats path=[7] (not
dataset:20110323-1620-9e0zjb30:720000000608 type Status with no value at
dataset=stats path=[8] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000607 type Status with no
value at dataset=stats path=[9] (not
dataset:20110323-1620-9e0zjb30:720000000600 type Status with no value at
dataset=stats path=[10] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000596 type Status with no
value at dataset=stats path=[11] (not
dataset:20110323-1620-9e0zjb30:720000000597 type Status with no value at
dataset=stats path=[12] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000594 type Status with no
value at dataset=stats path=[13] (not
dataset:20110323-1620-9e0zjb30:720000000595 type Status with no value at
dataset=stats path=[14] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110323-1620-9e0zjb30:720000000592 type Status with no
value at dataset=stats path=[15] (not
dataset:20110323-1620-9e0zjb30:720000000593 type Status with no value at
dataset=stats path=[16] (not closed)]
However, stats is closed with no listeners.
Status[] stats Closed, no listeners
How can the array be closed but all of its values not be? Attached is the
log for one of the runs that hangs.
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110323/0d03cc8a/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110323/0d03cc8a/attachment.obj>
