[Swift-devel] Swiftscript Iteration constructs, Clarification [GSoC 2011]
Yadu Nand yadudoc1729 at gmail.com
Tue Mar 22 15:27:53 CDT 2011
This is regarding the idea on adding map, fold, scan to succeed the
current iterative programming constructs (foreach, iterate).
Currently foreach follows the following structure :
file source[ ];
file destination[ ];
foreach value, index in source {
    destination[index]  =  func( value );
map could do the same using the structure :
destination = map ( func,  source )
Is this what is required ?
Furthermore,
The swift userguide[1] mentions VDL.g and XDTM.xsd but those files
are either missing or have (more likely) been renamed.
Instead I have been looking at which I believe is the renamed version:
resources/swiftscript.g
resources/swiftscript.xsd
Any inputs are welcome and appreciated.
[1]   http://www.ci.uchicago.edu/swift/guides/userguide.pdf
Thanks and Regards,
Yadu Nand B
