[Swift-devel] latest trunk
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Mar 22 00:31:04 CDT 2011
When the scheduler sees that no app is available on any site it should
complain and fail. Theoretically.
Logs may help. However, if not, it would be helpful to be able to
reproduce the problem (as in me being able to do so).
Mihael
On Mon, 2011-03-21 at 15:37 -0700, Sarah Kenny wrote:
> oh, problem was bad tc file...now i have to figure out why swift
> decided not to tell me that :P
> On Mon, Mar 21, 2011 at 3:29 PM, Sarah Kenny <skenny at uchicago.edu>
> wrote:
>         it works fine under .92 and is something i often use for
>         testing, but no worries i can debug more, i just thought maybe
>         there was a recent commit that would jump out at someone as
>         the potential cause of this behavior.
>         ~sk
>         On Mon, Mar 21, 2011 at 3:27 PM, Michael Wilde
>         <wilde at mcs.anl.gov> wrote:
>                 Sarah,
>                 I wont be able to test and help debug this today, but
>                 I notice that your app function declares but does not
>                 set the file return value "min".  Was (or is) the
>                 exact same script working under 0.92 in this manner?
>                 If you think this should work under trunk, I would
>                 first package up a version that anyone can run (ie
>                 include a mock RInvoke script, tc, sites, and
>                 properties file.
>                 The try to create a trunk version as of about a week
>                 or 2 ago, and see if you find find the trunk rev that
>                 broke it.
>                 If you can reproduce the error on latest trunk,
>                 posting the log and all the specs/files needed to run
>                 it would help Justin or Mihael try to find the
>                 problem.
>                 But first make sure the script is logically correct
>                 w.r.t the min return value. Looks wrong to me, but I
>                 may be missing something obvious.
>                 - Mike
>                 ______________________________________________________
>                         type file;
>                         type Rscript;
>                         type mxModel;
>                         app (mxModel min) mxModelProcessor(file
>                         covMatrix, Rscript mxModProc, int modnum,
>                         float weight, string cond)
>                                 RInvoke @filename(mxModProc)
>                         @filename(covMatrix) modnum weight cond;
>                         file
>                         covMatrix<single_file_mapper;file="./gestspeech.cov">;
>                         Rscript
>                         mxScript<single_file_mapper;file=@strcat("scripts/stest.R")>;
>                         int totalperms[] = [1:10];
>                         float initweight = .5;
>                         foreach perm in totalperms{
>                         mxModel modmin<single_file_mapper;
>                         file=@strcat("./results/speech_",perm,".rdata")>;
>                                 modmin = mxModelProcessor(covMatrix,
>                         mxScript, perm, initweight, "speech");
>                         the R script it calls is actually just a sleep
>                         job
>                         On Mon, Mar 21, 2011 at 2:57 PM, Michael Wilde
>                                 Can you post the script?
>                                         hmmm....so i just (a moment
>                                         ago) built from trunk and on a
>                                         quick test run (defaulting to
>                                         localhost) i seem to be
>                                         getting an infinite stream of
>                                         something like this:
>                                         No events in 10s.
>                                         Badness
>                                         Registered futures:
>                                         int[] totalperms  Closed, 10
>                                         elements, 0 listeners
>                                         Waiting threads:
>                                         0-4
>                                         No events in 10s.
>                                         Badness
>                                         Registered futures:
>                                         Waiting threads:
>                                         0-4
>                                         it's a simple test script that
>                                         runs fine in .92, anyone else
>                                         experiencing this?
>                                         Swift-devel mailing list
>                                         Swift-devel at ci.uchicago.edu
>                                         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>                                 Michael Wilde
>                                 Computation Institute, University of
>                                 Chicago
>                                 Mathematics and Computer Science
>                                 Division
>                                 Argonne National Laboratory
>                 Michael Wilde
>                 Computation Institute, University of Chicago
>                 Mathematics and Computer Science Division
