[Swift-devel] Running swift after fresh install giving errors
    Yadu Nand
    yadudoc1729 at gmail.com
    Sun Mar 20 16:49:43 CDT 2011
I am fairly new to swift and I'm getting the following error when I try to
run swift :
Error: SWIFT_HOME is not set, and all attempts at guessing it failed
I am using the development version and the build was reported to be
successful. Googling for this didn't help much and setting SWIFT_HOME
or swift.home manually is advised against here [1]. Nevertheless I tries
that as well to no use.
Any suggestion to fix this will be greatly appreciated.
The details of my system are :
Ubuntu 10.10
sun  Java version "1.6.0_24"
[1] http://www.ci.uchicago.edu/swift/guides/userguide.php
Thanks and Regards,
Yadu Nand B
(+91 94477 80725)
( http://humanint.posterous.com )
