[Swift-devel] Re: Proposal for coaster service options
Michael Wilde wilde at mcs.anl.gov
Fri Mar 18 09:58:47 CDT 2011
----- Original Message -----
> On Thu, 2011-03-17 at 23:43 -0500, Michael Wilde wrote:
> > > > One other item that came up in yesterday's meeting was the set
> > > > of
> > > > command line features to add to coaster-service (and to swift
> > > > itself
> > > > which we didnt mention) to put the integrated coaster service
> > > > into
> > > > passive mode and to make it save port numbers in a file for
> > > > integration with scripts.
> > > > That might be a good task to do soon if its easy/feasible.
> > > Yes. Seems like a quick and useful thing to have. Though doesn't
> > > the
> > > sites.xml scheme work in this case?
> > By "this case" do you mean the case where the coaster service is
> > running in the Swift JVM? I.e. from jobmanager=local:something in
> > the
> > coaster pool entry?
> I think I'm misunderstanding the issue.
> Are you referring to having the standalone service configured for
> passive mode?
Yes. The original mail I sent, proposing new command line options, was referring entirely to the coaster-service command.
In a later email, I realized that some of those issues might apply to the coaster service when running within the swift command's jvm as well.
- it seems that some or all of port management options (for setting and reporting port numbers) may apply to swift as well
- its likely that the option to set passive *does not* apply, as it already works. I think I was confused on the various combinations when I brought that up. Since currently we get the standalone service to enter passive mode by running a swift script that has passive mode set in the sites entry for that service, I realized on reflection that setting the passive option when the coaster service is running with the swift command JVM *must* be working correctly. It would be good to verify and create tests for this, but that is my current assumption.
Related to all this: I think that to do this job fully, we need to complete the set of wrapper commands that make manually run coasters an end-user-ready feature. And then to create scripts in the test framework to verify that they work. That will take more discussion, specification work, and devel time. But I feel we need to now get this feature completed and working, as there is user need for it.
Mihael, if you can get the changes into coaster-service and the swift command, I think others can get the wrapper scripts done and tested.
There is I think a prototype for this command support somewhere (Justin, you reminded me of these a few days ago: can you point out where they are?)
- Mike
