[Swift-devel] Executing a swift task from Java application
Ioan Raicu iraicu at cs.iit.edu
Fri Mar 11 16:02:30 CST 2011
Perhaps what you want is something like Falkon? Falkon is a stand-alone
system, that probably gives you most of the functionality of coasters.
If you are already familiar with the Swift code-base, perhaps its best
to figure out how to use coasters separately.
Ioan
Ioan Raicu, Ph.D.
Assistant Professor, Illinois Institute of Technology (IIT)
Guest Research Faculty, Argonne National Laboratory (ANL)
Data-Intensive Distributed Systems Laboratory, CS/IIT
Distributed Systems Laboratory, MCS/ANL
Cel:    1-847-722-0876
Office: 1-312-567-5704
Email:  iraicu at cs.iit.edu
Web:    http://www.cs.iit.edu/~iraicu/
Web:    http://datasys.cs.iit.edu/
On 3/11/2011 1:26 PM, Tim Armstrong wrote:
> Hi swift-devel,
>   I'm looking currently at using swift to manage files (staging in and
> out, etc) and execute tasks on behalf of another application.
> Is it possible to programmatically construct and execute Swift app
> tasks?  Would it make sense to just use the coasters module on its own
> without the Swift runtime?
> I've had a look through the swift code base, and it hasn't become
> obvious to me yet how I would achieve that, so I thought I should ask
> some people who know their way around the code better.  Is there a
> class or set of classes I should look at start looking at to
> understand how App tasks are instantiated and run?
> - Tim
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110311/86052cbf/attachment.html>
