[Swift-devel] swift on ranger
Ketan Maheshwari
ketancmaheshwari at gmail.com
Thu Jun 30 16:52:39 CDT 2011
On Thu, Jun 30, 2011 at 4:48 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> You should probably enable debugging for the sge provider. The package
> is:
> org.globus.cog.abstraction.impl.scheduler
I do not know how to do this. Should I put a line in log4j.properties:
org.globus.cog.abstraction.impl.scheduler=DEBUG
or make changes in the code?
> Then repost logs from runs with that enabled. Might show relevant stuff.
> On Thu, 2011-06-30 at 14:04 -0500, Ketan Maheshwari wrote:
> > Hi,
> > I am trying to run a simple catsn swift workflow on ranger/teragrid.
> > However, seems the SGE job does not get created on ranger host.
> > The staging-in of input files do happen from the communicado host to
> > ranger. The stdout on Swift shows status as job submitted, however
> > qsub on ranger does not show any jobs being submitted.
> > I am using the GRAM coaster provider: gt2:gt2:SGE
> > The logs and configuration files (cf, tc, sites.xml) for this run can
> > be found on CI network here:
> > /home/ketan/osg-tg-effort/ranger-catsn
> > Any help or tips to debug this further would be very useful.
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/9d9bda0a/attachment.html>
