[Swift-devel] New syntax for appending to arrays
Yadu Nand yadudoc1729 at gmail.com
Wed Jun 29 13:49:20 CDT 2011
> You shouldn't be seeing multiple threads with the same thread id.
I was working with this assumption.
I tried
int array[ ];
foreach outer in [1:2]{
foreach inner in [1:10]{
        array += inner;        trace(inner);
This works fine.
> For example, if you do this:
> foreach dummy in [1] {
>  foreach i in [1:10] {
>    a += i; // or whatever syntax was chosen to be? a << i ?
>  foreach value, key in a {
>  trace(key);
> should give 10 unique thread IDs as traced values. Those IDs won't be
> integers in general, though.
I am having some issue with array appends in nested loops. I'm pasting
the code here, I have attached the output, logs and kml generated.
Any help will be appreciated.
int array[ ][ ];
foreach dummy in [1:2] {
        array["key"] += 1;
        array["key"] += 2;
        foreach v in array["key"]{
        trace (v);
Thanks and Regards,
Yadu Nand B
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/f0ee47b1/attachment.obj>
Type: application/vnd.google-earth.kml+xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/f0ee47b1/attachment.kml>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/f0ee47b1/attachment.bin>
