[Swift-devel] writeData() output
Alberto Chavez alberto_chavez at live.com
Fri Jun 24 19:37:57 CDT 2011
Hi,I have been using suite.sh to run all available tests for swift, and there are a couple of them that use writeData() to generate output; however the output seems odd to me. For instance, the following script:
type file;
type S { string l; string c; string r; }
S s[];
file f <"writeDataStructArray2.out">;
f=writeData(s);
s[2].l = "baz";
s[2].c = "BAZ";
s[2].r = "Baz";
s[3].l = "qux";
s[3].c = "QUX";
s[3].r = "Qux";
s[0].l = "foo";
s[0].c = "FOO";
s[0].r = "Foo";
s[1].l = "bar";
s[1].c = "BAR";
s[1].r = "Bar";
s[4].l = "frrrr";
s[4].c = "FRRRR";
s[4].r = "Frrrr";Swift 0.92.1 generates writeDataStructArray2.out:r c l
Foo FOO foo
Bar BAR bar
Baz BAZ baz
Qux QUX qux
Frrrr FRRRR frrrr
But, Trunk generates writeDataStructArray2.outr c l
s[0].r:string = Foo - Closed s[0].c:string = FOO - Closed s[0].l:string = foo - Closed
s[1].r:string = Bar - Closed s[1].c:string = BAR - Closed s[1].l:string = bar - Closed
s[2].r:string = Baz - Closed s[2].c:string = BAZ - Closed s[2].l:string = baz - Closed
s[3].r:string = Qux - Closed s[3].c:string = QUX - Closed s[3].l:string = qux - Closed
s[4].r:string = Frrrr - Closed s[4].c:string = FRRRR - Closed s[4].l:string = frrrr - Closed
and I am uncertain whether to consider trunk output as correct or not.
Alberto.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110624/6a1660d3/attachment.html>
