[Swift-devel] Swift unresponsive while using local provider.
Mihael Hategan
hategan at mcs.anl.gov
Fri Jun 17 22:47:29 CDT 2011
On Fri, 2011-06-17 at 22:39 -0500, Alberto Chavez wrote:
> It hung on the 2nd iteration, attached is the output.
I would then say I don't believe you. Line 575 of AbstractDataNode is
not in addListener() in the latest svn code.
Make sure you have updated the code and re-compiled swift and that you
are running the correct version of swift. If in doubt post the log (it
contains the swift svn revision).
