[Swift-devel] Swift unresponsive while using local provider.
    Alberto Chavez
    alberto_chavez at live.com
    Fri Jun 17 22:22:12 CDT 2011
Attached is the output of the java process.
> Subject: RE: [Swift-devel] Swift unresponsive while using local provider.
> From: hategan at mcs.anl.gov
> To: alberto_chavez at live.com
> CC: davidkelly999 at gmail.com; swift-devel at ci.uchicago.edu
> Date: Fri, 17 Jun 2011 19:53:09 -0700
> On Fri, 2011-06-17 at 21:48 -0500, Alberto Chavez wrote:
> > > > $ jstack -l 2791
> > > And how did you come upon the number 2791?
> > that's the process ID of swift.
> There are two such process IDs. One belongs to the launcher script
> (bin/swift) and one to the java process. You'll need to use the java
> one. From the output you got, it's somewhat apparent that the PID you
> used was not that of a java process.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/ed3638ac/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/ed3638ac/attachment.bin>
