[Swift-devel] Re: [Bug 183] Print better error message when app executable is not found
Sarah Kenny
skenny at uchicago.edu
Wed Jun 15 13:15:47 CDT 2011
copying over to my own machine and running with stable release:
[skenny at martini missing_app]$ swift -tc.file ./tc.data tc_test.swift
Swift svn swift-r3876 cog-r3007
RunID: 20110615-1113-ef32g0te
Progress:
The executable /home/jonmon/Library/hello.sh does not exist
Progress: Stage in:1
Execution failed:
On Wed, Jun 15, 2011 at 10:04 AM, Jonathan Monette <jonmon at utexas.edu>wrote:
> In ~jonmon/test there is a script that reproduces this error I believe.
> The executable it is trying to use is in ~jonmon. The tc.data file points
> to ~jonmon/Library/hello.sh You should be able to run the script there in
> the directory. If not you can copy the files to yours and try it.
> On Jun 15, 2011, at 12:01 PM, Sarah Kenny wrote:
> yeah, if you're able to reproduce david that might be helpful. i get the
> same behavior with the stable release and trunk. i also get the correct
> error if i simply don't have execute permission on the executable.
> On Wed, Jun 15, 2011 at 9:37 AM, David Kelly <davidkelly999 at gmail.com>wrote:
>> Sarah,
>> I saw this error when I copied configuration files from one machine to
>> another. The application I was trying to run was in my home directory, but I
>> was logged in under a username so the path did not exist. The error message
>> I got was too vague to understand why my script failed - it was just
>> something like "Job failed with an exit code of 254". It didn't say which
>> job, or what that meant. I thought it was something related to the scheduler
>> I was trying to use. I have only tested this with 0.92.1. I did not try it
>> on trunk, so maybe this has already been fixed. I will try it again today to
>> see if I can reproduce it.
>> David
>> On Wed, Jun 15, 2011 at 1:05 AM, Sarah Kenny <skenny at uchicago.edu> wrote:
>>> hey david, i've been trying to replicate this bug, but when i
>>> deliberately point to an executable that doesn't exist i get what seems to
>>> be an appropriate error:
>>> The executable /bin/echoo does not exist
>>> i got this on a couple of sites...can you give a little more info on what
>>> was happening with your workflow? could be i'm misunderstanding the bug.
>>> ~sk
>>> On Fri, Jun 10, 2011 at 9:31 PM, <bugzilla-daemon at mcs.anl.gov> wrote:
>>>> https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=183
>>>> David Kelly <davidkelly999 at gmail.com> changed:
>>>> What |Removed |Added
>>>> CC| |davidkelly999 at gmail.com
>>>> Component|SwiftScript language |error messages
>>>> AssignedTo|benc at hawaga.org.uk |skenny at uchicago.edu
>>>> --- Comment #1 from David Kelly <davidkelly999 at gmail.com> 2011-06-10
>>>> 23:32:22 ---
>>>> This one gets my vote.. I just wasted a bunch of time trying to figure
>>>> out what
>>>> this error meant and why I was getting it.
>>>> Configure bugmail:
>>>> https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
>>>> ------- You are receiving this mail because: -------
>>>> You are the assignee for the bug.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110615/75189904/attachment.html>
