[Swift-devel] Re: Getting VMs from FG for use with swift
John Bresnahan
bresnaha at mcs.anl.gov
Wed Jun 8 11:46:01 CDT 2011
I am travelling back from HPDC tomorrow, but I could do Friday. I might be able to make it to UC in
the morning if that works.
On 06/08/2011 04:51 AM, Michael Wilde wrote:
> Hi John, David,
> A meeting sounds good. When are you in town? Or we can meet by phone tomorrow or Friday.
> Re Demos, we can pick from these to start:
> - a simple BLAST or "mock BLAST" demo: split a file, blast each segment against a DB,
> - protein-RNA docking with "modFTDock" (simple script, real science)
> - MODIS: analyze land use satellite data (has graphics)
> Mike
>> That sounds great. Perhaps we should have another meeting to discuss
>> what we can demo from here.
>> On 06/08/2011 02:38 AM, David Kelly wrote:
>>> It's not called directly from Swift, but the start-coaster-service
>>> script does that. It calls
>>> bootit.sh(cloudinitd), extracts information from the JSON output,
>>> sets up reverse SSH tunneling if
>>> needed, starts the worker perl script on each node, and then
>>> generates Swift configuration files
>>> with the correct values.
>>> David
>>> On Tue, Jun 7, 2011 at 11:27 PM, John Bresnahan
>>> <bresnaha at mcs.anl.gov<mailto:bresnaha at mcs.anl.gov>>
>>> wrote:
>>> Are we at a point where we can have cloudinit.d called from
>>> swift and have the hostnames parsed
>>> from the json output file? That might make a good demo.
>>> On 06/07/2011 03:01 PM, David Kelly wrote:
>>> Yep, I am using the VMs I get from cloudinitd with Swift.
>>> The only problem I sometimes notice is
>>> that cloudinitd can be pretty slow to finish.. somewhere
>>> between the point where it prints the
>>> information about the hosts (hostname, instance id, etc) but
>>> before it prints the success
>>> message
>>> and exits. I was thinking maybe it's related to the hotel
>>> filesystem problems from last
>>> week, but
>>> I'm not sure. Other times cloudinitd finishes quickly
>>> without any major delays.
>>> Once it gets past initializing the VMs it runs great. I've
>>> been testing with a script called
>>> hostsn.swift which basically just calls 'hostname' several
>>> times and sends the output to a file.
>>> It's useful for verifying that all the VMs are processing
>>> work. When you get a chance to test it
>>> out, the hostsn script is in the swift examples directory.
>>> You can call it with something
>>> like this:
>>> swift -sites.file sites.xml -tc.file tc.data -config cf
>>> hostsn.swift -n=100
>>> N is the number of 'hostname' processes to launch.. the
>>> files will be created in a directory
>>> called
>>> outdir.
>>> Feel free to send me an email when you get a chance to look
>>> at it and we can talk more about it.
>>> David
>>> On Tue, Jun 7, 2011 at 6:59 PM, John Bresnahan
>>> <mailto:bresnaha at mcs.anl.gov> <mailto:bresnaha at mcs.anl.gov
>>> <mailto:bresnaha at mcs.anl.gov>>>
>>> wrote:
>>> great! I will take a look at that when I can (I am on
>>> travel right now).
>>> Getting back to using cloudinit.d for swift... we you
>>> able to use the VMs you got from
>>> FutureGrid with swift? I was hoping we could start
>>> encorperating that into swift, or at
>>> least
>>> acquire a set of VMs and use those as you currently use
>>> static machines in some demos.
>>> From: "David Kelly"<davidkelly999 at gmail.com
>>> <mailto:davidkelly999 at gmail.com>
>>> <mailto:davidkelly999 at gmail.com>>>
>>> To: "John Bresnahan"<bresnaha at mcs.anl.gov
>>> <mailto:bresnaha at mcs.anl.gov<mailto:bresnaha at mcs.anl.gov>>>
>>> Cc: "Mike Wilde"<wilde at mcs.anl.gov
>>> <mailto:wilde at mcs.anl.gov> <mailto:wilde at mcs.anl.gov
>>> <mailto:wilde at mcs.anl.gov>>>, "swift-devel"
>>> <swift-devel at ci.uchicago.edu
>>> <mailto:swift-devel at ci.uchicago.edu>
>>> <mailto:swift-devel at ci.uchicago.edu>>>
>>> Sent: Tuesday, June 7, 2011 2:39:20 PM
>>> Subject: Re: Getting VMs from FG for use with swift
>>> Hello John,
>>> I have attached a quickstart guide I wrote on how to get
>>> Swift working with futuregrid
>>> by using
>>> the new Swift coaster service scripts. This will require
>>> the latest development version of
>>> Swift. Instructions on how to download/install are in
>>> the document.
>>> Please let me know if you have any questions, if
>>> anything is unclear, or if you run into any
>>> problems. Thank you!
>>> Regards,
>>> David
>>> On Tue, May 24, 2011 at 3:18 PM, John Bresnahan<
>>> > wrote:
>>> The GPFS server on the FG cluster hotel died yesterday
>>> so I cannot get you your credentials.
>>> I'll get back to you when it is up again. Once it is
>>> back the process for getting the
>>> needed
>>> access keys is described here:
>>> https://portal.futuregrid.org/tutorials/nimbus
>>> On 05/23/2011 05:24 AM, David Kelly wrote:
>>> Hi John,
>>> I now have a futuregrid account and am added to a
>>> project. I am now trying to get our
>>> scripts
>>> working together.
>>> I ran into a few problems at first when trying to run
>>> the futuregrid scripts. On the
>>> first system I
>>> tried I was getting a traceback. It is possible that the
>>> system I was using has older
>>> versions of
>>> some of the needed libraries. Then I tried it on a more
>>> system that is more frequently
>>> updated - my
>>> laptop running Ubuntu 10.10. It needed a newer version
>>> of the Python crypto tools
>>> installed, so I
>>> installed that (and the python development libraries)
>>> and that part seems fine now.
>>> I am now up to the point of the install script where it
>>> is trying to register keys, but
>>> it is
>>> failing. My guess is that I need to change
>>> FUTUREGRID_IAAS_ACCESS_KEY and
>>> FUTUREGRID_IAAS_SECRET_KEY
>>> in env.sh. I'm not sure what these should be exactly.
>>> Are these the contents of my ssh
>>> keys, an ssh
>>> key and a passphrase, or some other type of security?
>>> I've tried a few combinations of
>>> different
>>> things but haven't had much luck yet.
>>> Thanks!
>>> Regards,
>>> David
>>> Traceback from earlier:
>>> Installing setuptools.......................done.
>>> Complete output from command
>>> /autonfs/home/davidk/swift-vm-...ython
>>> /autonfs/home/davidk/swift-vm-...stall pip:
>>> Searching for pip
>>> Reading http://pypi.python.org/simple/pip/
>>> Reading http://pip.openplans.org
>>> Reading http://www.pip-installer.org
>>> Best match: pip 1.0.1
>>> Downloading
>>> http://pypi.python.org/packages/source/p/pip/pip-1.0.1.tar.gz#md5=28dcc70225e5bf925532abc5b087a94b
>>> Processing pip-1.0.1.tar.gz
>>> Running pip-1.0.1/setup.py -q bdist_egg --dist-dir
>>> /tmp/easy_install-GHsjHX/pip-1.0.1/egg-dist-tmp-rXjQ7L
>>> Traceback (most recent call last):
>>> File
>>> "/autonfs/home/davidk/swift-vm-boot/ve/bin/easy_install",
>>> line 8, in<module>
>>> load_entry_point('setuptools==0.6c11',
>>> 'console_scripts', 'easy_install')()
>>> File
>>> "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/command/easy_install.py",
>>> line 1712, in main
>>> File
>>> line 1700, in with_ei_usage
>>> File
>>> line 1716, in<lambda>
>>> File
>>> "/soft/python-2.6.1-r1/lib/python2.6/distutils/core.py",
>>> line 152, in setup
>>> dist.run_commands()
>>> File
>>> "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py",
>>> line 975, in run_commands
>>> self.run_command(cmd)
>>> File
>>> line 995, in run_command
>>> cmd_obj.run()
>>> File
>>> line 211, in run
>>> File
>>> line 446, in easy_install
>>> File
>>> line 476, in install_item
>>> File
>>> line 655, in install_eggs
>>> File
>>> line 930, in build_and_install
>>> File
>>> line 919, in run_setup
>>> File
>>> "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/sandbox.py",
>>> line 52, in run_setup
>>> AttributeError: 'module' object has no attribute
>>> '__getstate__'
>>> File "bin/virtualenv.py", line 1647, in<module>
>>> main()
>>> File "bin/virtualenv.py", line 558, in main
>>> prompt=options.prompt)
>>> File "bin/virtualenv.py", line 656, in
>>> create_environment
>>> install_pip(py_executable)
>>> File "bin/virtualenv.py", line 415, in install_pip
>>> filter_stdout=_filter_setup)
>>> File "bin/virtualenv.py", line 624, in
>>> call_subprocess
>>> % (cmd_desc, proc.returncode))
>>> OSError: Command /autonfs/home/davidk/swift-vm-...ython
>>> failed with error code 1
>>> Failed to created the needed python virtual environment
>>> On Fri, May 20, 2011 at 7:20 PM, John Bresnahan<
>>> <mailto: bresnaha at mcs.anl.gov
>>> <mailto:bresnaha at mcs.anl.gov>> >>
>>> wrote:
>>> Our phone call today left me motiviated to show you
>>> guys how easy it is to get
>>> virtual machines
>>> for use with swift on FutureGrid.
>>> I made some small scripts around the Nimbus tool
>>> cloudinitd. The scripts just make
>>> installing
>>> the software and running it trivial. With a single
>>> command you can get N VMs from the
>>> FutureGrid Nimbus clouds (N can be on the order of
>>> hundreds). When the tool is done
>>> it outputs
>>> a line separated list of hostnames. All of these
>>> hostnames have root access
>>> available via your
>>> ~/.ssh/id_rsa keys.
>>> If/when you have FutureGrid credentials, untar the
>>> attachment and give it a try.
>>> There are a
>>> few minor configurations needed:
>>> 1) edit the file env.sh and set your FutureGrid
>>> security credentials:
>>> % cat env.sh
>>> export FUTUREGRID_IAAS_ACCESS_KEY=XXXXXXXXXXXXXXXXXX
>>> export
>>> FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>>> export FUTUREGRID_HOTEL_NODES=2
>>> export FUTUREGRID_SIERRA_NODES=2
>>> You can also change the value '2' to be whatever
>>> number of VMs you want.
>>> 2) install it on your system. (this single command
>>> downloads and installs
>>> everything you need
>>> under the cwd):
>>> % ./install.sh
>>> 3) boot the VMs
>>> % ./bin/bootit.sh.
>>> You will see much status output, but the last several
>>> lines will be the hostnames
>>> acquired from
>>> the cloud.
>>> Let me know when you guys are ready to check this
>>> out!
