[Swift-devel] Re: Getting VMs from FG for use with swift
    John Bresnahan
    bresnaha at mcs.anl.gov
    Wed Jun  8 08:44:40 CDT 2011
That sounds great.  Perhaps we should have another meeting to discuss what we can demo from here.
On 06/08/2011 02:38 AM, David Kelly wrote:
> It's not called directly from Swift, but the start-coaster-service script does that. It calls
> bootit.sh(cloudinitd), extracts information from the JSON output, sets up reverse SSH tunneling if
> needed, starts the worker perl script on each node, and then generates Swift configuration files
> with the correct values.
> David
> On Tue, Jun 7, 2011 at 11:27 PM, John Bresnahan <bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>
> wrote:
>     Are we at a point where we can have cloudinit.d called from swift and have the hostnames parsed
>     from the json output file?  That might make a good demo.
>     On 06/07/2011 03:01 PM, David Kelly wrote:
>         Yep, I am using the VMs I get from cloudinitd with Swift. The only problem I sometimes notice is
>         that cloudinitd can be pretty slow to finish.. somewhere between the point where it prints the
>         information about the hosts (hostname, instance id, etc) but before it prints the success
>         message
>         and exits. I was thinking maybe it's related to the hotel filesystem problems from last
>         week, but
>         I'm not sure. Other times cloudinitd finishes quickly without any major delays.
>         Once it gets past initializing the VMs it runs great. I've been testing with a script called
>         hostsn.swift which basically just calls 'hostname' several times and sends the output to a file.
>         It's useful for verifying that all the VMs are processing work. When you get a chance to test it
>         out, the hostsn script is in the swift examples directory. You can call it with something
>         like this:
>         swift -sites.file sites.xml -tc.file tc.data -config cf hostsn.swift -n=100
>         N is the number of 'hostname' processes to launch.. the files will be created in a directory
>         called
>         outdir.
>         Feel free to send me an email when you get a chance to look at it and we can talk more about it.
>         David
>         On Tue, Jun 7, 2011 at 6:59 PM, John Bresnahan <bresnaha at mcs.anl.gov
>         <mailto:bresnaha at mcs.anl.gov> <mailto:bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>>
>         wrote:
>             great!  I will take a look at that when I can (I am on travel right now).
>             Getting back to using cloudinit.d for swift... we you able to use the VMs you got from
>             FutureGrid with swift?  I was hoping we could start encorperating that into swift, or at
>         least
>             acquire a set of VMs and use those as you currently use static machines in some demos.
>             ----- Original Message -----
>             From: "David Kelly" <davidkelly999 at gmail.com <mailto:davidkelly999 at gmail.com>
>         <mailto:davidkelly999 at gmail.com <mailto:davidkelly999 at gmail.com>>>
>             To: "John Bresnahan" <bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>
>             Cc: "Mike Wilde" <wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov> <mailto:wilde at mcs.anl.gov
>         <mailto:wilde at mcs.anl.gov>>>, "swift-devel"
>         <swift-devel at ci.uchicago.edu <mailto:swift-devel at ci.uchicago.edu>
>         <mailto:swift-devel at ci.uchicago.edu <mailto:swift-devel at ci.uchicago.edu>>>
>             Sent: Tuesday, June 7, 2011 2:39:20 PM
>             Subject: Re: Getting VMs from FG for use with swift
>             Hello John,
>             I have attached a quickstart guide I wrote on how to get Swift working with futuregrid
>         by using
>             the new Swift coaster service scripts. This will require the latest development version of
>             Swift. Instructions on how to download/install are in the document.
>             Please let me know if you have any questions, if anything is unclear, or if you run into any
>             problems. Thank you!
>             Regards,
>             David
>             On Tue, May 24, 2011 at 3:18 PM, John Bresnahan < bresnaha at mcs.anl.gov
>         <mailto:bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>> > wrote:
>             The GPFS server on the FG cluster hotel died yesterday so I cannot get you your credentials.
>               I'll get back to you when it is up again.  Once it is back the process for getting the
>         needed
>             access keys is described here:
>         https://portal.futuregrid.org/tutorials/nimbus
>             On 05/23/2011 05:24 AM, David Kelly wrote:
>             Hi John,
>             I now have a futuregrid account and am added to a project. I am now trying to get our
>         scripts
>             working together.
>             I ran into a few problems at first when trying to run the futuregrid scripts. On the
>         first system I
>             tried I was getting a traceback. It is possible that the system I was using has older
>         versions of
>             some of the needed libraries. Then I tried it on a more system that is more frequently
>         updated - my
>             laptop running Ubuntu 10.10.  It needed a newer version of the Python crypto tools
>         installed, so I
>             installed that (and the python development libraries) and that part seems fine now.
>             I am now up to the point of the install script where it is trying to register keys, but
>         it is
>             failing. My guess is that I need to change FUTUREGRID_IAAS_ACCESS_KEY and
>         FUTUREGRID_IAAS_SECRET_KEY
>             in env.sh. I'm not sure what these should be exactly. Are these the contents of my ssh
>         keys, an ssh
>             key and a passphrase, or some other type of security? I've tried a few combinations of
>         different
>             things but haven't had much luck yet.
>             Thanks!
>             Regards,
>             David
>             Traceback from earlier:
>             Installing setuptools.......................done.
>                Complete output from command /autonfs/home/davidk/swift-vm-...ython
>             /autonfs/home/davidk/swift-vm-...stall pip:
>                Searching for pip
>             Reading http://pypi.python.org/simple/pip/
>             Reading http://pip.openplans.org
>             Reading http://www.pip-installer.org
>             Best match: pip 1.0.1
>             Downloading
>         http://pypi.python.org/packages/source/p/pip/pip-1.0.1.tar.gz#md5=28dcc70225e5bf925532abc5b087a94b
>             Processing pip-1.0.1.tar.gz
>             Running pip-1.0.1/setup.py -q bdist_egg --dist-dir
>             /tmp/easy_install-GHsjHX/pip-1.0.1/egg-dist-tmp-rXjQ7L
>             Traceback (most recent call last):
>                File "/autonfs/home/davidk/swift-vm-boot/ve/bin/easy_install", line 8, in <module>
>                  load_entry_point('setuptools==0.6c11', 'console_scripts', 'easy_install')()
>                File
>         "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/command/easy_install.py",
>             line 1712, in main
>                File
>             line 1700, in with_ei_usage
>                File
>             line 1716, in <lambda>
>                File "/soft/python-2.6.1-r1/lib/python2.6/distutils/core.py", line 152, in setup
>                  dist.run_commands()
>                File "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py", line 975, in run_commands
>                  self.run_command(cmd)
>                File "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py", line 995, in run_command
>                  cmd_obj.run()
>                File
>             line 211, in run
>                File
>             line 446, in easy_install
>                File
>             line 476, in install_item
>                File
>             line 655, in install_eggs
>                File
>             line 930, in build_and_install
>                File
>             line 919, in run_setup
>                File
>         "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/sandbox.py",
>             line 52, in run_setup
>             AttributeError: 'module' object has no attribute '__getstate__'
>                File "bin/virtualenv.py", line 1647, in <module>
>                  main()
>                File "bin/virtualenv.py", line 558, in main
>                  prompt=options.prompt)
>                File "bin/virtualenv.py", line 656, in create_environment
>                  install_pip(py_executable)
>                File "bin/virtualenv.py", line 415, in install_pip
>                  filter_stdout=_filter_setup)
>                File "bin/virtualenv.py", line 624, in call_subprocess
>                  % (cmd_desc, proc.returncode))
>             OSError: Command /autonfs/home/davidk/swift-vm-...ython
>             failed with error code 1
>             Failed to created the needed python virtual environment
>             On Fri, May 20, 2011 at 7:20 PM, John Bresnahan < bresnaha at mcs.anl.gov
>         <mailto:bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>> <mailto: bresnaha at mcs.anl.gov
>         <mailto:bresnaha at mcs.anl.gov> <mailto:bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>> >>
>             wrote:
>                 Our phone call today left me motiviated to show you guys how easy it is to get
>         virtual machines
>                 for use with swift on FutureGrid.
>                 I made some small scripts around the Nimbus tool cloudinitd.  The scripts just make
>         installing
>                 the software and running it trivial.  With a single command you can get N VMs from the
>                 FutureGrid Nimbus clouds (N can be on the order of hundreds).  When the tool is done
>         it outputs
>                 a line separated list of hostnames.  All of these hostnames have root access
>         available via your
>                 ~/.ssh/id_rsa keys.
>                 If/when you have FutureGrid credentials, untar the attachment and give it a try.
>           There are a
>                 few minor configurations needed:
>                 1) edit the file env.sh and set your FutureGrid security credentials:
>                 % cat env.sh
>                 export FUTUREGRID_IAAS_ACCESS_KEY=XXXXXXXXXXXXXXXXXX
>                 export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>                 export FUTUREGRID_HOTEL_NODES=2
>                 export FUTUREGRID_SIERRA_NODES=2
>                 You can also change the value '2' to be whatever number of VMs you want.
>                 2) install it on your system.  (this single command downloads and installs
>         everything you need
>                 under the cwd):
>                 % ./install.sh
>                 3) boot the VMs
>                 % ./bin/bootit.sh.
>             You will see much status output, but the last several lines will be the hostnames
>         acquired from
>                 the cloud.
>                 Let me know when you guys are ready to check this out!
