[Swift-devel] Re: Getting VMs from FG for use with swift
John Bresnahan bresnaha at mcs.anl.gov
Tue Jun 7 23:27:35 CDT 2011
Are we at a point where we can have cloudinit.d called from swift and have the hostnames parsed from
the json output file?  That might make a good demo.
On 06/07/2011 03:01 PM, David Kelly wrote:
> Yep, I am using the VMs I get from cloudinitd with Swift. The only problem I sometimes notice is
> that cloudinitd can be pretty slow to finish.. somewhere between the point where it prints the
> information about the hosts (hostname, instance id, etc) but before it prints the success message
> and exits. I was thinking maybe it's related to the hotel filesystem problems from last week, but
> I'm not sure. Other times cloudinitd finishes quickly without any major delays.
> Once it gets past initializing the VMs it runs great. I've been testing with a script called
> hostsn.swift which basically just calls 'hostname' several times and sends the output to a file.
> It's useful for verifying that all the VMs are processing work. When you get a chance to test it
> out, the hostsn script is in the swift examples directory. You can call it with something like this:
> swift -sites.file sites.xml -tc.file tc.data -config cf hostsn.swift -n=100
> N is the number of 'hostname' processes to launch.. the files will be created in a directory called
> outdir.
> Feel free to send me an email when you get a chance to look at it and we can talk more about it.
> David
> On Tue, Jun 7, 2011 at 6:59 PM, John Bresnahan <bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>
> wrote:
>     great!  I will take a look at that when I can (I am on travel right now).
>     Getting back to using cloudinit.d for swift... we you able to use the VMs you got from
>     FutureGrid with swift?  I was hoping we could start encorperating that into swift, or at least
>     acquire a set of VMs and use those as you currently use static machines in some demos.
>     ----- Original Message -----
>     From: "David Kelly" <davidkelly999 at gmail.com <mailto:davidkelly999 at gmail.com>>
>     To: "John Bresnahan" <bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>
>     Cc: "Mike Wilde" <wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov>>, "swift-devel"
>     <swift-devel at ci.uchicago.edu <mailto:swift-devel at ci.uchicago.edu>>
>     Sent: Tuesday, June 7, 2011 2:39:20 PM
>     Subject: Re: Getting VMs from FG for use with swift
>     Hello John,
>     I have attached a quickstart guide I wrote on how to get Swift working with futuregrid by using
>     the new Swift coaster service scripts. This will require the latest development version of
>     Swift. Instructions on how to download/install are in the document.
>     Please let me know if you have any questions, if anything is unclear, or if you run into any
>     problems. Thank you!
>     Regards,
>     David
>     On Tue, May 24, 2011 at 3:18 PM, John Bresnahan < bresnaha at mcs.anl.gov
>     <mailto:bresnaha at mcs.anl.gov> > wrote:
>     The GPFS server on the FG cluster hotel died yesterday so I cannot get you your credentials.
>       I'll get back to you when it is up again.  Once it is back the process for getting the needed
>     access keys is described here:
>     https://portal.futuregrid.org/tutorials/nimbus
>     On 05/23/2011 05:24 AM, David Kelly wrote:
>     Hi John,
>     I now have a futuregrid account and am added to a project. I am now trying to get our scripts
>     working together.
>     I ran into a few problems at first when trying to run the futuregrid scripts. On the first system I
>     tried I was getting a traceback. It is possible that the system I was using has older versions of
>     some of the needed libraries. Then I tried it on a more system that is more frequently updated - my
>     laptop running Ubuntu 10.10.  It needed a newer version of the Python crypto tools installed, so I
>     installed that (and the python development libraries) and that part seems fine now.
>     I am now up to the point of the install script where it is trying to register keys, but it is
>     failing. My guess is that I need to change FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY
>     in env.sh. I'm not sure what these should be exactly. Are these the contents of my ssh keys, an ssh
>     key and a passphrase, or some other type of security? I've tried a few combinations of different
>     things but haven't had much luck yet.
>     Thanks!
>     Regards,
>     David
>     Traceback from earlier:
>     Installing setuptools.......................done.
>        Complete output from command /autonfs/home/davidk/swift-vm-...ython
>     /autonfs/home/davidk/swift-vm-...stall pip:
>        Searching for pip
>     Reading http://pypi.python.org/simple/pip/
>     Reading http://pip.openplans.org
>     Reading http://www.pip-installer.org
>     Best match: pip 1.0.1
>     Downloading
>     http://pypi.python.org/packages/source/p/pip/pip-1.0.1.tar.gz#md5=28dcc70225e5bf925532abc5b087a94b
>     Processing pip-1.0.1.tar.gz
>     Running pip-1.0.1/setup.py -q bdist_egg --dist-dir
>     /tmp/easy_install-GHsjHX/pip-1.0.1/egg-dist-tmp-rXjQ7L
>     Traceback (most recent call last):
>        File "/autonfs/home/davidk/swift-vm-boot/ve/bin/easy_install", line 8, in <module>
>          load_entry_point('setuptools==0.6c11', 'console_scripts', 'easy_install')()
>        File
>     "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/command/easy_install.py",
>     line 1712, in main
>        File
>     line 1700, in with_ei_usage
>        File
>     line 1716, in <lambda>
>        File "/soft/python-2.6.1-r1/lib/python2.6/distutils/core.py", line 152, in setup
>          dist.run_commands()
>        File "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py", line 975, in run_commands
>          self.run_command(cmd)
>        File "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py", line 995, in run_command
>          cmd_obj.run()
>        File
>     line 211, in run
>        File
>     line 446, in easy_install
>        File
>     line 476, in install_item
>        File
>     line 655, in install_eggs
>        File
>     line 930, in build_and_install
>        File
>     line 919, in run_setup
>        File
>     "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/sandbox.py",
>     line 52, in run_setup
>     AttributeError: 'module' object has no attribute '__getstate__'
>        File "bin/virtualenv.py", line 1647, in <module>
>          main()
>        File "bin/virtualenv.py", line 558, in main
>          prompt=options.prompt)
>        File "bin/virtualenv.py", line 656, in create_environment
>          install_pip(py_executable)
>        File "bin/virtualenv.py", line 415, in install_pip
>          filter_stdout=_filter_setup)
>        File "bin/virtualenv.py", line 624, in call_subprocess
>          % (cmd_desc, proc.returncode))
>     OSError: Command /autonfs/home/davidk/swift-vm-...ython /autonfs/home/davidk/swift-vm-...stall pip
>     failed with error code 1
>     Failed to created the needed python virtual environment
>     On Fri, May 20, 2011 at 7:20 PM, John Bresnahan < bresnaha at mcs.anl.gov
>     <mailto:bresnaha at mcs.anl.gov> <mailto: bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov> >>
>     wrote:
>         Our phone call today left me motiviated to show you guys how easy it is to get virtual machines
>         for use with swift on FutureGrid.
>         I made some small scripts around the Nimbus tool cloudinitd.  The scripts just make installing
>         the software and running it trivial.  With a single command you can get N VMs from the
>         FutureGrid Nimbus clouds (N can be on the order of hundreds).  When the tool is done it outputs
>         a line separated list of hostnames.  All of these hostnames have root access available via your
>         ~/.ssh/id_rsa keys.
>         If/when you have FutureGrid credentials, untar the attachment and give it a try.  There are a
>         few minor configurations needed:
>         1) edit the file env.sh and set your FutureGrid security credentials:
>         % cat env.sh
>         export FUTUREGRID_IAAS_ACCESS_KEY=XXXXXXXXXXXXXXXXXX
>         export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>         export FUTUREGRID_HOTEL_NODES=2
>         export FUTUREGRID_SIERRA_NODES=2
>         You can also change the value '2' to be whatever number of VMs you want.
>         2) install it on your system.  (this single command downloads and installs everything you need
>         under the cwd):
>         % ./install.sh
>         3) boot the VMs
>         % ./bin/bootit.sh.
>     You will see much status output, but the last several lines will be the hostnames acquired from
>         the cloud.
>         Let me know when you guys are ready to check this out!
