[Swift-devel] Walltime in PBS submit files
Tim Armstrong tim.g.armstrong at gmail.com
Fri Jun 3 10:21:31 CDT 2011
I'd been trying separately to understand the effect of the maxTime
parameter: it doesn't do what I intuitively expect it to either.  It seems
like if I set maxtime to x number of minutes, it submits jobs of at most x -
1 minutes duration.
Is this the intended behaviour?  Is maxTime rounded down to the nearest
minute?  Should I understand maxTime as meaning "only submit jobs that are
strictly less than durations"?
- Tim
On Fri, Jun 3, 2011 at 10:15 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Could you add a note on this to the trunk user guide?
> Thanks,
> Mike
> That did the trick. I bumped up the maxtime to 300 and it ran immediately.
> Thanks for the info!
> David
> On Fri, Jun 3, 2011 at 9:54 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> David,
>> Im not sure what coasters is thinking here.  But first thing I would try
>> is to set the maxtime value in sites.xml (which is in integer seconds) to
>> something like 300 to make coasters realize that it can fit at least 10
>> 30-second app calls into the 300 second coaster block.
>> With maxtime < maxwalltime coasters may be erroneously starting a block
>> but finding that its unable to fit *any* app calls into it.
>> There are also settings you can apply (overallocation etc) to make maxtime
>> more of an "exact time" setting. For example, if you do this:
>>     <profile namespace="globus" key="maxTime">1800</profile>
>>     <profile namespace="globus" key="lowOverAllocation">100</profile>
>>     <profile namespace="globus" key="highOverAllocation">100</profile>
>> ...then each coaster block started should have a maxwalltime of 1800 secs.
>> But your app maxwalltime needs to fit into this block time.
>> - Mike
>> Hello,
>> I am trying to use the shared queue on Fusion. This queue requires a
>> walltime of less than one hour. I have all of the applications in my tc.data
>> file set up with a walltime of 30 seconds. In my sites.xml, I specify a
>> maxtime of 10. However, when Swift generates the PBS submit file, it
>> specifies a walltime of 00:00:00 which prevents it from running.
>> How can I make Swift set the walltime in these PBS submit scripts?
>> Thanks,
>> David
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110603/134286d2/attachment.html>
