[Swift-devel] recent error on beagle
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Thu Jun  2 16:21:42 CDT 2011
Mihael:  thanks, I appreciate it, sorry to bug you
Mike: this problem was occuring to me on PADS (the thread was originally
about a similar problem on Beagle).  I haven't made any progress debugging
the issue on beagle, beyond coming up with the minimal example to replicate
it.  I managed to pare down the example even more: it deadlocks if the
pthread library is linked dynamically, even if no pthreads functions are
actually used. Ie. the deadlock happens at the time the shared library is
loaded.  I unsuccessfully attempted some different workarounds.  I'm pretty
much out of ideas on how to make progress on this - getting Cray in on the
problem might be best at this point.
- Tim
On Thu, Jun 2, 2011 at 3:39 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Yes. Sorry about the delay. The word is that I need to backport the
> patch from trunk to 0.92 and then have a patch release. I was waiting
> for words from other folks, and I got that yesterday. I will be doing
> this as soon as I have some time, which is probably somewhere between
> today and next Tuesday.
> Mihael
> On Thu, 2011-06-02 at 15:24 -0500, Tim Armstrong wrote:
> > Any word on this bug?  I have a nice use-case for SwiftR where it
> > would be very handy to take advantage of Swift's dynamic resource
> > procurement.
> > - Tim
> > On Thu, May 26, 2011 at 3:41 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         Given that this has now been reported a number of times, it
> >         may make
> >         sense to backport the fix from trunk and make a patch release
> >         for 0.92.
> >         Objections?
> >         On Thu, 2011-05-26 at 14:59 -0500, Tim Armstrong wrote:
> >         > Hi,
> >         >   I've encountered this issue with SwiftR, running release
> >         0.92 from
> >         > the svn repository.  The issue occurs when
> >         > GLOBUS::maxWallTime="03:55:00" in tc and maxTime is 4 hours
> >         in
> >         > sites.xml.  After 5 minutes (or whatever the difference is
> >         between the
> >         > two times), I get the exception copied below.  A tarball is
> >         attached
> >         > with the logs, script, etc.  replicate.sh shows how to
> >         replicate the
> >         > issue on PADS.
> >         > Assuming that my problem is the same as the others, it would
> >         be good
> >         > if the fix could be merged to release 0.92, as I'm trying to
> >         bundle
> >         > stable swift releases with SwiftR.
> >         > - Tim
> >         > Swift svn swift-r4336 cog-r3096 (cog modified locally)
> >         > RunID: 20110526-1317-2c8ybi10
> >         > Progress:
> >         > SwiftScript trace: top of loop: rserver waiting for input
> >         > on, /tmp/nbest/SwiftR/swift.0827/requestpipe
> >         > Progress:  Active:1
> >         > Progress:  Finished successfully:1
> >         > SwiftScript trace: rserver: got
> >         > dir, /tmp/nbest/SwiftR/requests.P09626/R0000007
> >         > Progress:  uninitialized:1  Finished successfully:1
> >         > Progress:  Submitted:1  Finished successfully:1
> >         > Progress:  Active:1  Finished successfully:1
> >         > queuedsize > 0 but no job dequeued. Queued: {}
> >         > java.lang.Throwable
> >         >         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
> >         >         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
> >         >         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
> >         > java.lang.Throwable
> >         >         at
> >         >         at
> >         >         at
> >         > Progress:  Finished successfully:1 Failed but can retry:1
> >         > On Sun, May 22, 2011 at 1:51 PM, Mihael Hategan
> >         > wrote:
> >         >         The second one looks to me like a coaster problem.
> >         Can't say
> >         >         much about
> >         >         the first issue.
> >         >         Can you try with plain pbs if you want to test the
> >         pbs
> >         >         provider?
> >         >         Mihael
> >         >         On Sun, 2011-05-22 at 08:39 -0500, ketan wrote:
> >         >         > I can confirm that the trunk is not usable for pbs
> >         provider.
> >         >         I am using
> >         >         > trunk for submitting jobs on beagle and I see a
> >         few
> >         >         unexpected things:
> >         >         > 1. The stderr is showing inconsistent messages:
> >         The results
> >         >         are getting
> >         >         > written to the output even though stderr doesn't
> >         report any.
> >         >         > 2. qsub jobs being cancelled inadvertantly: I
> >         submitted 40
> >         >         of them
> >         >         > yesterday, however, only 2 survived today. The log
> >         is here:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-0337-pokpgg89.log
> >         >         > In addition, the ssh-pbs provider does not seem to
> >         be
> >         >         working for large
> >         >         > runs (it worked for a small number of test runs):
> >         Getting
> >         >         unexpected
> >         >         > stdouts. Following is the stdout:
> >         http://www.ci.uchicago.edu/~ketan/files/ssh-pbs.stdout
> >         >         > Following is the log file for the above run:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-1750-b0cot9sa.log
> >         >         > Ketan
> >         >         > On 5/21/11 5:12 PM, Michael Wilde wrote:
> >         >         > > ----- Original Message -----
> >         >         > >> On Sat, 2011-05-21 at 17:06 -0400, Glen Hocky
> >         wrote:
> >         >         > >>> as I mentioned, I've been running with Mike's
> >         swift
> >         >         which was
> >         >         > >>> patched
> >         >         > >>> for beagle. are all the things that make
> >         running on
> >         >         beagle work in
> >         >         > >>> trunk?
> >         >         > >> No idea.
> >         >         > >> Mike?
> >         >         > > Justin, working with Ketan, just applied changes
> >         to trunk
> >         >         which should make it work now on Beagle (or any Cray
> >         XT5+ or
> >         >         XE).  This uses a different set of sites.xml tags
> >         than the
> >         >         prototype in the current Beagle swift 0.92.1 module.
> >         Justin
> >         >         has a note on this at:
> >          https://sites.google.com/site/swiftdevel/sites/pbs/cray
> >         >         > > It was working before for one-node worker jobs;
> >         now it
> >         >         should work for multi-node worker jobs as well.
> >         >         > > Justin and Ketan should comment on the state of
> >         testing
> >         >         and readiness of this trunk feature.  Don't try
> >         trunk on
> >         >         Beagle till they give the go-ahead.
> >         >         > > - Mike
> >         >         > >>>   If so i'll update to the latest and test. I
> >         don't
> >         >         think I'm
> >         >         > >>> using stable...
> >         >         > >> Ok
> >         >         > >> Mihael
> >         >         > _______________________________________________
> >         >         > Swift-devel mailing list
> >         >         > Swift-devel at ci.uchicago.edu
> >         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110602/378334e1/attachment.html>
