[Swift-devel] recent error on beagle
Michael Wilde
wilde at mcs.anl.gov
Thu Jun 2 15:31:51 CDT 2011
Tim, in addition: whats the status of the problem of not being able to launch two concurrent R applications on the same compute node?
The problem below implies that you've resolved this prior problem? If so, what was the resolution?
Mike
----- Original Message -----
Any word on this bug? I have a nice use-case for SwiftR where it would be very handy to take advantage of Swift's dynamic resource procurement.
- Tim
On Thu, May 26, 2011 at 3:41 PM, Mihael Hategan < hategan at mcs.anl.gov > wrote:
Given that this has now been reported a number of times, it may make
sense to backport the fix from trunk and make a patch release for 0.92.
Objections?
On Thu, 2011-05-26 at 14:59 -0500, Tim Armstrong wrote:
> Hi,
> I've encountered this issue with SwiftR, running release 0.92 from
> the svn repository. The issue occurs when
> GLOBUS::maxWallTime="03:55:00" in tc and maxTime is 4 hours in
> sites.xml. After 5 minutes (or whatever the difference is between the
> two times), I get the exception copied below. A tarball is attached
> with the logs, script, etc. replicate.sh shows how to replicate the
> issue on PADS.
> Assuming that my problem is the same as the others, it would be good
> if the fix could be merged to release 0.92, as I'm trying to bundle
> stable swift releases with SwiftR.
> - Tim
> Swift svn swift-r4336 cog-r3096 (cog modified locally)
> RunID: 20110526-1317-2c8ybi10
> Progress:
> SwiftScript trace: top of loop: rserver waiting for input
> on, /tmp/nbest/SwiftR/swift.0827/requestpipe
> Progress: Active:1
> Progress: Finished successfully:1
> SwiftScript trace: rserver: got
> dir, /tmp/nbest/SwiftR/requests.P09626/R0000007
> Progress: uninitialized:1 Finished successfully:1
> Progress: Submitted:1 Finished successfully:1
> Progress: Active:1 Finished successfully:1
> queuedsize > 0 but no job dequeued. Queued: {}
> java.lang.Throwable
> at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
> java.lang.Throwable
> at
> at
> at
> Progress: Finished successfully:1 Failed but can retry:1
> On Sun, May 22, 2011 at 1:51 PM, Mihael Hategan < hategan at mcs.anl.gov >
> wrote:
> The second one looks to me like a coaster problem. Can't say
> much about
> the first issue.
> Can you try with plain pbs if you want to test the pbs
> provider?
> Mihael
> On Sun, 2011-05-22 at 08:39 -0500, ketan wrote:
> > I can confirm that the trunk is not usable for pbs provider.
> I am using
> > trunk for submitting jobs on beagle and I see a few
> unexpected things:
> > 1. The stderr is showing inconsistent messages: The results
> are getting
> > written to the output even though stderr doesn't report any.
> > 2. qsub jobs being cancelled inadvertantly: I submitted 40
> of them
> > yesterday, however, only 2 survived today. The log is here:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-0337-pokpgg89.log
> > In addition, the ssh-pbs provider does not seem to be
> working for large
> > runs (it worked for a small number of test runs): Getting
> unexpected
> > stdouts. Following is the stdout:
> > http://www.ci.uchicago.edu/~ketan/files/ssh-pbs.stdout
> > Following is the log file for the above run:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-1750-b0cot9sa.log
> > Ketan
> > >> On Sat, 2011-05-21 at 17:06 -0400, Glen Hocky wrote:
> > >>> as I mentioned, I've been running with Mike's swift
> which was
> > >>> patched
> > >>> for beagle. are all the things that make running on
> beagle work in
> > >>> trunk?
> > >> No idea.
> > >> Mike?
> > > Justin, working with Ketan, just applied changes to trunk
> which should make it work now on Beagle (or any Cray XT5+ or
> XE). This uses a different set of sites.xml tags than the
> prototype in the current Beagle swift 0.92.1 module. Justin
> has a note on this at:
> > > https://sites.google.com/site/swiftdevel/sites/pbs/cray
> > > It was working before for one-node worker jobs; now it
> should work for multi-node worker jobs as well.
> > > Justin and Ketan should comment on the state of testing
> and readiness of this trunk feature. Don't try trunk on
> Beagle till they give the go-ahead.
> > > - Mike
> > >>> If so i'll update to the latest and test. I don't
> think I'm
> > >>> using stable...
> > >> Ok
> > >> Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110602/c4f0581e/attachment.html>
