[Swift-devel] Re: SCEC postproc workflow unresponsive after first 2 tasks
ketan ketancmaheshwari at gmail.com
Thu Jun 2 10:30:39 CDT 2011
Ok, done this. On another trial, seems the workflow is progressing,
however, after a few hours, I get the following errors:
Final status:  Initializing:2636  Failed:393  Finished successfully:395
The following errors have occurred:
1. Server refused performing the request. Custom message: Bad password.
(error code 1) [Nested exception message:  Custom message: Unexpected
reply: 530-Login incorrect. : globus_gss_assist: Gridmap lookup failure:
Could not map /DC=org/DC=doegrids/OU=People/CN=Ketan Maheshwari 64821
530-
530 End.] (393 times)
2. Application seispeak_agg not executed due to errors in dependencies
(216 times)
3. Application seispeak_local not executed due to errors in dependencies
(2420 times)
While, I am debugging, kindly let me know if these message ring any bells.
Ketan
On 6/1/11 1:02 PM, Allan Espinosa wrote:
> Hi Ketan,
> Could you add debugging for Swift's vdl:stagein calls?  Also, is this
> using the stable branch?
> Here's the log4j.properties I always use:
> # Set root category priority to WARN and its appenders to CONSOLE and FILE.
> log4j.rootCategory=INFO, CONSOLE, FILE
> log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
> log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
> log4j.appender.CONSOLE.Threshold=INFO
> log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
> log4j.appender.FILE=org.apache.log4j.FileAppender
> log4j.appender.FILE.File=swift.log
> log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
> log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
> HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
> log4j.logger.swift=DEBUG
> log4j.logger.org.apache.axis.utils=ERROR
> log4j.logger.org.globus.swift.trace=INFO
> log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
> log4j.logger.org.globus.cog.karajan.workflow.events.WorkerSweeper=WARN
> log4j.logger.org.globus.cog.karajan.workflow.nodes.FlowNode=WARN
> log4j.logger.org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler=DEBUG
> log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
> log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=INFO
> log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
> log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
> log4j.logger.org.globus.cog.abstraction.coaster.rlog=DEBUG
> # log4j.logger.org.globus.swift.data.Director=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.lib=INFO
> log4j.logger.org.griphyn.vdl.karajan.lib.SetFieldValue=OFF
> log4j.logger.org.griphyn.vdl.mapping.AbstractDataNode=OFF
> # Transfer
> #log4j.logger.org.globus.ftp=DEBUG
> #log4j.logger.org.globus.gridftp=DEBUG
> -Allan
> 2011/6/1 ketan<ketancmaheshwari at gmail.com>:
>> Allan,
>> I tried to run the posproc workflow on the OSG whitelisted resources.
>> However, the workflow seems not to respond after completing the first two
>> tasks:
>> I get something like this:
>> Progress:  Selecting site:248  Stage in:2  Finished successfully:2
>> The sites.xml, tc.data and the log files are on bridled as follows:
>> /home/ketan/osg-tg-effort/cybershake/condor_osg.xml
>> /home/ketan/osg-tg-effort/cybershake/tc.data
>> /home/ketan/osg-tg-effort/cybershake/postproc-20110601-0951-43n3a22g.log
>> Swift is:
>> [bridled.ci.uchicago.edu:cybershake]$ which swift
>> swift is /home/ketan/swift-0.92.1/bin/swift
>> I have memcached on, sourced /opt/osg-1.x.x/setup.sh and have a valid proxy.
>> Could you indicate what are the first debugging steps that I should be
>> taking on osg in such condition?
>> Thanks,
>> Ketan
