[Swift-devel] typed keys
Mihael Hategan
hategan at mcs.anl.gov
Sun Jul 24 14:34:20 CDT 2011
On Sun, 2011-07-24 at 10:42 +0000, Ben Clifford wrote:
> > > introduce runtime type errors: 5+"monkey" (for example) or inability
> > > to add two numbers (5+5 = TYPE ERROR! because those 5s happen to be
> > > Objects not numbers)
> > You would not be able to use these things in any other context than the
> > places that accept the any type. Such as trace() and whatever else is
> > there that fits, but not "+".
> So should this work? O rather, how liberal does compile time type checking
> have to be to allow it to work at runtime?
> int a[]; int b[]
> populate(a); populate(b); // with number indices
> for v,k in a {
> for u,l in b {
> o[k*1000 + l] = f(u,v)
Yeah, this should work. It would also allow mixed types:
a[1] = 1; a["b"] = 2;
You won't be able to say:
f(int) {}
foreach v, k in a {
f(k);
But that is fine. If you want that, you can declare a as int[int], and
then you can't have a["b"].
Though this issue is purely hypothetical at this point. It's not the
solution I would favor.
What I favor is auto. We're basically adding the append, so to keep it
separate from everything else we have so far, we would associate it with
the auto type.
> Its something that works at the moment. I don't think this style is used a
> huge amount but I think it has been done in the past. Constructing string
> indices by concatenating things is another example of the same, I think.
> With a runtime top-type, the compile time checking needs to be quite
> loose, I think - here k and l are used numerically, but if you're keeping
> the discovery of the numericness 'till runtime, then you can't know at
> compile time.
Again, you wouldn't be able to use an "any" as an int.
> Maybe that is an argument in favour of some compile time inference.
Loosely.
