[Swift-devel] Swift demos on ideone.com or similar?
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jul 15 08:32:18 CDT 2011
Yadu, I just noticed your link to ideone.com, and realized what that site is about.
Do you already have Swift running there? If not, what's involved in setting that up?
Can runs there run on remote resources?
Ketan mentioned a similar idea a while back (I cant recall what demo site it was) but no one has had time to pursue it.
Also Jon is getting Swift running on Globus Online at the moment; maybe these things could link to each other (eg an ideone.com demo that can also run tiny scripts on GO resources).
This might be nice to brainstorm as you seem to be familiar with ideone.
- Mike
----- Original Message -----
> On Fri, Jul 15, 2011 at 1:53 AM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > On Fri, 2011-07-15 at 01:12 +0530, Yadu Nand wrote:
> >> > If there are things in your code that you feel are hackish (i.e.
> >> > quick
> >> > solutions that seem shady for production), let's discuss/fix them
> >> > before
> >> > we do the above.
> >> Yes! In org/griphyn/vdl/engine/Karajan.java, the foreachstat
> >> function is
> >> mostly hacks. I'm putting in a code paste : http://ideone.com/yWbwU
> > It would be helpful if you were more specific (i.e. you could
> > describe
> > each individual problem).
> Ok.
> When we state foreach value, index in array[5] I'm trying to match the
> type of array which from the "in" variable type, something like
> int [int] against int [int][string] so that we get the type of the
> index.
> I think we could do this better with regex and here I'm having to
> extract
> the array identifier using very bad string matching. Then we find the
> index type and apply it.
> That would be between line number 40 and 75 of the code pasted
> here -> http://ideone.com/yWbwU
> Thanks and Regards,
> Yadu Nand B
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
