[Swift-devel] Updates - Tests
Yadu Nand
yadudoc1729 at gmail.com
Thu Jul 14 17:00:55 CDT 2011
On Fri, Jul 15, 2011 at 1:53 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2011-07-15 at 01:12 +0530, Yadu Nand wrote:
>> > If there are things in your code that you feel are hackish (i.e. quick
>> > solutions that seem shady for production), let's discuss/fix them before
>> > we do the above.
>> Yes! In org/griphyn/vdl/engine/Karajan.java, the foreachstat function is
>> mostly hacks. I'm putting in a code paste : http://ideone.com/yWbwU
> It would be helpful if you were more specific (i.e. you could describe
> each individual problem).
Ok.
When we state foreach value, index in array[5] I'm trying to match the
type of array which from the "in" variable type, something like
int [int] against int [int][string] so that we get the type of the index.
I think we could do this better with regex and here I'm having to extract
the array identifier using very bad string matching. Then we find the
index type and apply it.
That would be between line number 40 and 75 of the code pasted
here -> http://ideone.com/yWbwU
Thanks and Regards,
Yadu Nand B
