[Swift-devel] OSG hang
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Jul 14 16:47:16 CDT 2011
Ok.  I set GLOBUS_TCP_PORT_RANGE and GLOBUS_TCP_SOURCE_RANGE to 50000,51000 and GLOBUS_HOSTNAME to the ec2 ip-address.  Setting these variables seemed to have resolved this issue.  I can execute Swift on the VM to sites from OSG. I can see the sleep job running on the head node of the OSG site and when it finishes Swift also shuts down.
On Jul 14, 2011, at 4:26 PM, Mihael Hategan wrote:
> On Thu, 2011-07-14 at 16:11 -0500, Michael Wilde wrote:
>> Jack tells me you cant ping EC2 VMs form outside because they block ICMP.
>> Check with Jack on what you need to do (if anything) to make sure ports 50000 through 51000 are open, and then make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_TCP_SOURCE_RANGE are set to 50000,51000
>> Then make sure (via say the nc or netcat commands) that you can connect to those ports from the OSG site.
>> If all that works, then work with Mihael to test a simple Karajan
>> script that submits a job.  There are examples of these from Allan
>> in /home/wilde/swift/lab/osg/allantools (or nearby there)
> There's also swift/bin/checksites.k
> run it with "swift checksites.k <your_sites.xml>"
> You may want to edit it and change the timeout value to something more
> than 10s (given that OSG uses managed fork - i.e. fork jobs have a queue
> of their own, hence they are not immediate).
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
