[Swift-devel] Fwd: trunk FileNotFoundException
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Jul 12 14:16:52 CDT 2011
Mihael,
I tried to further investigate the issue and from the logs it seems that
Swift is trying to execute the mkoffset app before creating a jobs/
directory in workdir. Could it be that this is an ordering issue. For
instance, I see the following line:
2011-07-12 13:50:49,559-0500 DEBUG vdl:execute2 JOB_START
jobid=mkoffset-mex8fvck tr=mkoffset arguments=[200.0, 60.0]
tmpdir=postproc-20110712-1343-eczky6ob/jobs/m/mkoffset-mex8fvck
host=localhost
but do not see a createdir corresponding to above.
I have ran this workflow successfully with 0.92.1 so, I am pretty sure that
it works correctly as far as order of execution is concerned.
Thanks for any more insights into this.
Ketan
---------- Forwarded message ----------
From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
Date: Mon, Jul 11, 2011 at 10:31 PM
Subject: trunk FileNotFoundException
To: swift-user at ci.uchicago.edu
Hello,
Using Swift trunk, I am running the SCEC workflow from Communicado using
ranger, localhost and OSG resources.
One particular app 'mkoffset' which is destined to run on localhost is
faulting with FileNotFoundException.
The log does give information on its mapping and when it gets 'cleared'.
The config, tc, sites and log files for the run could be found here:
http://www.mcs.anl.gov/~ketan/files/bundle.tgz (log is 90M, upload size
exceeded!)
The error stack that I am getting on stdout is:
Progress:  time: Mon, 11 Jul 2011 22:16:38 -0500  Selecting site:390  Stage
in:16  Active:9  Checking status:1  Finished successfully:36 Failed but can
retry:3
org.globus.cog.abstraction.impl.file.FileNotFoundException: File not found:
/var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/stderr.txt
    at
org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
    at
org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:268)
    at
org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:158)
    at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:314)
    at
org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
    at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:487)
    at java.lang.Thread.run(Thread.java:619)
/var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/LGU/offset-128
    at
    at
    at
    at
    at
    at
Progress:  time: Mon, 11 Jul 2011 22:16:39 -0500  Selecting site:389  Stage
in:16  Active:9  Checking status:1  Finished successfully:38 Failed but can
retry:4
Execution failed:
    java.lang.NullPointerException
    at
org.griphyn.vdl.mapping.AbstractDataNode.getValue(AbstractDataNode.java:333)
    at org.griphyn.vdl.karajan.lib.SetFieldValue.log(SetFieldValue.java:71)
    at
org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:38)
    at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:62)
    at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
    at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
    at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
    at
org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
    at
    at
    at
    at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:66)
    at
    at
    at
Any clues?
Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110712/f7005289/attachment.html>
