[Swift-devel] NumberFormatException
    Jonathan Monette
    jonmon at utexas.edu
    Mon Jul 11 14:30:34 CDT 2011
Mihael,
   I am getting this error using release 0.92.1.
2011-07-11 19:24:44,395+0000 INFO  unknown RUNID id=run:20110711-1924-c944yl9c
2011-07-11 19:24:44,508+0000 DEBUG VDL2ExecutionContext vdl:new @ script.kml, line: 69: java.lang.RuntimeException: java.lang.NumberFormatException: For input string: ""
Caused by: java.lang.RuntimeException: java.lang.NumberFormatException: For input string: ""
	at org.griphyn.vdl.mapping.AbsFile.exists(AbsFile.java:109)
	at org.griphyn.vdl.mapping.file.SingleFileMapper.existing(SingleFileMapper.java:24)
	at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:97)
	at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:75)
	at org.griphyn.vdl.mapping.RootDataNode.innerInit(RootDataNode.java:61)
	at org.griphyn.vdl.mapping.RootDataNode.init(RootDataNode.java:37)
	at org.griphyn.vdl.karajan.lib.New.function(New.java:126)
	at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:68)
	at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
	at org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:32)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:340)
	at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:173)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:181)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:309)
	at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
	at org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:290)
	at org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
	at org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:45)
	at org.globus.cog.karajan.workflow.nodes.functions.Map_Map.post(Map_Map.java:55)
	at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:50)
	at org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:44)
	at org.globus.cog.karajan.workflow.nodes.Each.post(Each.java:31)
	at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
	at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:26)
	at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:238)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:289)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:402)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:343)
	at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:44)
	at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
	at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
	at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
	at java.lang.Thread.run(Thread.java:636)
Caused by: java.lang.NumberFormatException: For input string: ""
	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
	at java.lang.Integer.parseInt(Integer.java:493)
	at java.lang.Integer.parseInt(Integer.java:514)
	at org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.parse(ServiceContactImpl.java:90)
	at org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.<init>(ServiceContactImpl.java:27)
	at org.griphyn.vdl.mapping.AbsFile.getFileResource(AbsFile.java:84)
	at org.griphyn.vdl.mapping.AbsFile.exists(AbsFile.java:99)
	... 63 more
The files needed for this run are located in ~jonmon/run.0000 on the ci machines.
