[Swift-devel] readData2
Mihael Hategan hategan at mcs.anl.gov
Wed Jul 6 12:30:26 CDT 2011
I think that the first priority is to have one format able to support
all swift structures. And that is what readData2 did. But I like the
idea of being able to supply a format as you mention below.
So it's probably a smart thing to not rename anything at this point but
introduce the read(format=) scheme below and slowly deprecate readData
and readData2.
On Wed, 2011-07-06 at 11:16 -0500, David Kelly wrote:
> Would it make sense to replace readData and readStructured with one
> flexible function which could use multiple formats? For example:
> foo = read( -type="JSON", -file="myfile.json" );
> I think JSON, XML, and CSV would be useful to have in addition to the
> two existing Swift formats.
> David
> On Fri, Jul 1, 2011 at 9:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
> wrote:
>         fopen(3) is smart enough to know that "r" means read.
>          Certainly Swift is
>         smarter than fopen.
>         However, I think there is a lot of value in allowing users to
>         read
>         unformatted, "one value per line" data and I don't think we
>         should force
>         users to convert possibly large text files into Swift format.
>          So, I think
>         there is value in keeping the two functionalities separate.
>         If we're going to mandate a file format, we should try to be
>         compatible
>         with JSON or something.  But I don't think we should mandate a
>         file
>         format.
>                Justin
>         On Fri, 1 Jul 2011, Tim Armstrong wrote:
>         > You could go full unix shell style and call it "rd"
>         > On Fri, Jul 1, 2011 at 6:09 PM, Mihael Hategan
>         <hategan at mcs.anl.gov> wrote:
>         >> On Fri, 2011-07-01 at 18:04 -0700, Sarah Kenny wrote:
>         >>> my 2 cents...readStruct...slightly more succinct :)
>         >> 2 more cents: read. Can't get much better than that.
>         >>> On Fri, Jul 1, 2011 at 4:22 PM, Jonathan S Monette
>         <jonmon at utexas.edu>
>         >>> wrote:
>         >>>         I am all for dropping readData. writeData would
>         have to be
>         >>>         modified to output data for "readData2".
>         >>>         Do you have a better name? I thought maybe
>         readMapping or
>         >>>         readExplicitMapping but Justin said the mapping
>         term maybe
>         >>>         should not be used in this case.
>         >>>         On Jul 1, 2011 6:12 PM, "Mihael Hategan"
>         >>>         wrote:
>         >>>        > On Thu, 2011-06-30 at 13:40 -0500, Jonathan
>         Monette wrote:
>         >>>        >> Hello,
>         >>>        >> I am going to rename readData2 to something more
>         >>>         meaningful. I am
>         >>>        >> thinking maybe readStructured? I will keep
>         readData2 as an
>         >>>         alias to
>         >>>        >> the renamed function as too not break anyones
>         current code
>         >>>         but the
>         >>>        >> userguide will reflect the renamed function. Any
>         >>>         suggestions on the
>         >>>        >> name or is readStructured good?
>         >>>        > I think we should drop readData and slowly
>         replace it with
>         >>>         readData2.
>         >>>        > readStructured doesn't seem to be more
>         illuminating to me.
>         >>>         _______________________________________________
>         >>>         Swift-devel mailing list
>         >>>         Swift-devel at ci.uchicago.edu
>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>         >>> Sarah Kenny
>         >>> Programmer
>         >>> University of Chicago, Computation Institute
>         >>> University of California Irvine, Dept. of Neurology
>         >>> 773-818-8300
>         Justin M Wozniak
