[Swift-devel] readData2
    Ben Clifford
    benc at hawaga.org.uk
    Mon Jul  4 10:00:25 CDT 2011
>     I am going to rename readData2 to something more meaningful.  I am
> thinking maybe readStructured?  I will keep readData2 as an alias to the
> renamed function as too not break anyones current code but the userguide
> will reflect the renamed function.  Any suggestions on the name or is
> readStructured good?
Something that I did when renaming things before was to make the old name
issue a warning when used, for a couple of releases, and then remove. That
was an attempt at a balance between not breaking things and preventing the
long term build-up of detritus.
